ESP8266 2MB + OTA
JulienInnovel
ESP8266 2MB + OTA
Postby JulienInnovel » Tue Feb 06, 2018 1:01 am
Hello everyone,
I'm using an ESP-WROOM-02 (ESP8266 + 2MB of SPI flash).
I'm trying to do OTA tests with mode 512KB + 512KB, to have 1024KB of user data (I have some data do store into flash and I don't want to erase them with OTA, user data stored at @ 0x100000).
I build my first firmware (V1) with linker script "eagle.app.v6.new.2048.ld", option "16m" (not "16m-c1").
I flash my ESP with ESP FLASH TOOL with this parameters :
SPI speed : 40MHz
SPI mode : QIO
Flash size : 16m
and files :
boot_v1.7.bin @0x00000
user1.bin @0x01000
blank.bin @0x1fb000
esp_init_data_default.bin @0x1fc000
blank.bin @0x1fe000
My ESP start correctly (USART prompt ) :
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 16Mbit(512KB+512KB)
jump to run user1 @ 1000
rf cal sector: 507
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
w_flash
SDK ver: 2.1.0(116b762) compiled @ May 5 2017 16:08:55
phy ver: 1134_0, pp ver: 10.2
Now, I want to upgrade my ESP by OTA to firmware version 2 (same as version 1 but only version number has changed) :
It's working perfectly, reboot and prompt this :
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2 @ 81000
rf cal sector: 507
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
Now, I want to upgrade to the firmware version 3 (same has others, but only version number changed to 3) :
GET /user1.bin HTTP/1.0
Connection: close
actual bin : UPGRADE_FW_BIN2
system_upgrade_start
upgrade_connect 45736
[OTA]Upgrading...
upgrade_connect_cb
pusrdata = HTTP/1.0 200 OK
Content-Type: application/octet-stream
Content-Length: 234820
sumlength = 234820
sec_block 58
..........................................................upgrade_get_sum_disconcb 45544
And nothing else.... Reboot it self and only print this :
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
And my ESP is broken...
I must erase all, and flash it again.
It seems like the firmware 2 is erasing itself or something else..
Any one have any idea ?
Re: ESP8266 2MB + OTA
Postby AgentSmithers » Wed Feb 07, 2018 2:36 am
I just went through some OTA troubleshooting with another member on the forum here. Want to do a skype chat and I can take a look and help you fix it? I have some cycles starting thursday night PST.
JulienInnovel
Postby JulienInnovel » Wed Feb 07, 2018 8:56 pm
Hi, thanks.
You can add me, my skype is j.reynaud_7
JulienInnovel
Postby JulienInnovel » Thu Feb 08, 2018 5:28 pm
If I use the linker for 1MB (512+512), it seems to work !
I have the bootloader for 16Mbit (512 + 512) and I can use OTA to flash firmware and automatically jump to user 1 or user 2, and have a user data flash at the end (from @0x100000 to @0x1FC000).
But, why I must use the 1MB linker ?
The linker for 2MB can't do 512+512 ?
Postby Her Majesty » Mon Feb 12, 2018 5:27 pm
Did you select the 16Mbit on your flash download tool while downing?
And you should note that the system parameter area is always the last 4 or 5 sectors of your flash (16Mbit), you should not save any user data there.
JulienInnovel
Postby JulienInnovel » Mon Feb 12, 2018 6:55 pm
Yes, I select the 16Mbit flash when I download the firmware.
My user data selection is from @0x100000 to @0x1FC000 (like defined in the IOT SDK USER MANUAL).
Postby AgentSmithers » Sun Feb 18, 2018 2:03 pm
JulienInnovel wrote:Hi, thanks.
I added you but havent been accepted yet.
Users browsing this forum: Bing [Bot] and 11 guests
