esp8266 nonos sdk 2.2.0 ota flash_crc!=img_crc
limuzi2012
Postby limuzi2012 » Fri Mar 16, 2018 8:51 am
otallen = 358876
totallen = 360336
totallen = 361396
upgrade file download finished.
flash_crc = 3525425237
[08:40:28.378]收←◆img_crc = 645727078
upgrade_check
[OTA]failed!
limuzi2012
Re: esp8266 nonos sdk 2.2.0 ota flash_crc!=img_crc
Postby limuzi2012 » Sat Mar 17, 2018 11:59 am
like this website :https://stackoverflow.com/questions/47147491/esp8266-nonos-sdk-fota-error-check-the-bin-file
#define pheadbuffer "Connection: keep-alive\r\n\
Cache-Control: no-cache\r\n\
\r\n"
void ICACHE_FLASH_ATTR ota_start_Upgrade(uint8_t serverVersion, const char *server_ip, uint16_t port, const char *path)
   const char* file;
   uint8_t userBin = system_upgrade_userbin_check();
   switch (userBin)
   case UPGRADE_FW_BIN1: file = "user2.4096.new.4.bin"; break; //  user2.bin
   case UPGRADE_FW_BIN2: file = "user1.4096.new.4.bin"; break; // user1.bin
   default:
      os_printf("[OTA]Invalid userbin number!\n");
      return;
   os_printf("[OTA]system user version: %d\n", userBin);
   uint16_t version=1;
   if (serverVersion <= version)
      os_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
      return;
   os_printf("[OTA]Upgrade available version: %d\n", serverVersion);
   struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
   update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
   os_memcpy(update->ip, server_ip, 4);
   update->port = port;
   os_printf("[OTA]Server "IPSTR":%d. Path: [%s],file: [%s]\n", IP2STR(update->ip), update->port, path, file);
   update->check_cb = ota_finished_callback;
   update->check_times = 120000;
   update->url = (uint8 *)os_zalloc(512);
   os_sprintf((char*)update->url,
      "GET /%s%s HTTP/1.1\r\n"
      "Host: "IPSTR":%d\r\n"
      pheadbuffer,
      path, file, IP2STR(update->ip), update->port);
   if (system_upgrade_start(update) == false)
      os_printf("[OTA]Could not start upgrade\n");
      os_free(update->pespconn);
      os_free(update->url);
      os_free(update);
   else
      os_printf("[OTA]Upgrading...\n");
\r\n"
const char* file;
switch (userBin)
default:
return;
uint16_t version=1;
return;
pheadbuffer,
os_free(update);
else
Postby Her Mary » Tue Mar 27, 2018 5:45 pm
There is a simple demo may help. https://bbs.espressif.com/viewtopic.php?f=7&t=423#p1619
For the log you provided, it is the CRC error, maybe you should check the data you downloaded from the server, maybe it has not only the bin but also some HTTP header which cause the CRC fail.
