[ESP Smart Config] Adding other functions after Smart Config
bonchenko
Postby bonchenko » Wed Jun 17, 2015 6:32 pm
Hello, I am trying to add smartconfig to esp_mqtt project by tuanpm - http://tuanpm.net/native-mqtt-client-li ... r-esp8266/
For smartconfig, I have used and tested it. I used app from this github repository IOT-Espressif-Android and use espressif iot SDK v1.1.1. They work perfectly.
Unfortunately, adding any code from esp_mqtt cause the firmware to not working anymore. I am still looking on how to use smartconfig and esp_mqtt together. I attached my code:
 * Copyright 2013-2014 Espressif Systems (Wuxi)
 * FileName: user_main.c
 * Description: entry file of user application
 * Modification history:
 *     2014/1/1, v1.0 create this file.
#include "ets_sys.h"
#include "osapi.h"
#include "driver/uart.h"
#include "smartconfig.h"
#include "user_interface.h"
#include "mqtt.h"
#include "wifi.h"
#include "config.h"
#include "debug.h"
#include "gpio.h"
#include "mem.h"
sc_type SC_Type = 0;
MQTT_Client mqttClient;
void wifiConnectCb(uint8_t status)
    if(status == STATION_GOT_IP){
        MQTT_Connect(&mqttClient);
    } else {
        MQTT_Disconnect(&mqttClient);
void mqttConnectedCb(uint32_t *args)
    MQTT_Client* client = (MQTT_Client*)args;
    INFO("MQTT: Connected\r\n");
    MQTT_Subscribe(client, "/mqtt/topic/0", 0);
    MQTT_Subscribe(client, "/mqtt/topic/1", 1);
    MQTT_Subscribe(client, "/mqtt/topic/2", 2);
    MQTT_Publish(client, "/mqtt/topic/0", "hello0", 6, 0, 0);
    MQTT_Publish(client, "/mqtt/topic/1", "hello1", 6, 1, 0);
    MQTT_Publish(client, "/mqtt/topic/2", "hello2", 6, 2, 0);
void mqttDisconnectedCb(uint32_t *args)
    INFO("MQTT: Disconnected\r\n");
void mqttPublishedCb(uint32_t *args)
    INFO("MQTT: Published\r\n");
void mqttDataCb(uint32_t *args, const char* topic, uint32_t topic_len, const char *data, uint32_t data_len)
    char *topicBuf = (char*)os_zalloc(topic_len+1),
            *dataBuf = (char*)os_zalloc(data_len+1);
    os_memcpy(topicBuf, topic, topic_len);
    topicBuf[topic_len] = 0;
    os_memcpy(dataBuf, data, data_len);
    dataBuf[data_len] = 0;
    INFO("Receive topic: %s, data: %s \r\n", topicBuf, dataBuf);
    os_free(topicBuf);
    os_free(dataBuf);
void ICACHE_FLASH_ATTR
smartconfig_done(sc_status status, void *pdata)
    switch(status) {
        case SC_STATUS_WAIT:
            os_printf("SC_STATUS_WAIT\n");
            break;
        case SC_STATUS_FIND_CHANNEL:
            os_printf("SC_STATUS_FIND_CHANNEL\n");
            break;
        case SC_STATUS_GETTING_SSID_PSWD:
            os_printf("SC_STATUS_GETTING_SSID_PSWD\n");
            break;
        case SC_STATUS_LINK:
            os_printf("SC_STATUS_LINK\n");
            struct station_config *sta_conf = pdata;
           wifi_station_set_config(sta_conf);
           wifi_station_disconnect();
           wifi_station_connect();
            break;
        case SC_STATUS_LINK_OVER:
            os_printf("SC_STATUS_LINK_OVER\n");
            if (SC_Type == SC_TYPE_ESPTOUCH) {
                uint8 phone_ip[4] = {0};
                os_memcpy(phone_ip, (uint8*)pdata, 4);
                os_printf("Phone ip: %d.%d.%d.%d\n",phone_ip[0],phone_ip[1],phone_ip[2],phone_ip[3]);
            smartconfig_stop();
            break;
void user_rf_pre_init(void)
void user_init(void)
   uart_init(BIT_RATE_115200, BIT_RATE_115200);
   os_delay_us(1000000);
   SC_Type = SC_TYPE_ESPTOUCH;
    smartconfig_start(SC_Type, smartconfig_done);
   CFG_Load();
    MQTT_InitConnection(&mqttClient, sysCfg.mqtt_host, sysCfg.mqtt_port, sysCfg.security);
    //MQTT_InitConnection(&mqttClient, "192.168.11.122", 1880, 0);
    MQTT_InitClient(&mqttClient, sysCfg.device_id, sysCfg.mqtt_user, sysCfg.mqtt_pass, sysCfg.mqtt_keepalive, 1);
    //MQTT_InitClient(&mqttClient, "client_id", "user", "pass", 120, 1);
    MQTT_InitLWT(&mqttClient, "/lwt", "offline", 0, 0);
    MQTT_OnConnected(&mqttClient, mqttConnectedCb);
    MQTT_OnDisconnected(&mqttClient, mqttDisconnectedCb);
    MQTT_OnPublished(&mqttClient, mqttPublishedCb);
    MQTT_OnData(&mqttClient, mqttDataCb);
    WIFI_Connect(sysCfg.sta_ssid, sysCfg.sta_pwd, wifiConnectCb);
    INFO("\r\nSystem started ...\r\n");
Here is my correct smartconfig output:
And this is what happen when I add esp_mqtt code:
Now, I think this is because in the SDK docs, it states that smartconfig_start must run alone, we cannot run other code with it. My question is, how can I run other function in ESP8266 after smartconfig finished?
ESP_Alfred
Re: [ESP Smart Config] Adding other functions after Smart Co
Postby ESP_Alfred » Thu Jun 18, 2015 11:31 am
hi,
ESP8266 in smartconfig-ing, the Station mode and SoftAP mode should be closed. so the network connection could't work.
if you want to run other function, may be after smartconfig_stop()
smartconfig_stop();
/*run other function*/
break;
