Request for new IDF based development
jhinkle
Postby jhinkle » Sat Sep 29, 2018 12:26 am
I just started using the ESP32 IDF and the ESP8266-Rtos IDF.
Initially I thought the component config menu would allow me to remove specific components from the build process.
Example - I don't use SSL, MQTT, etc
I was disappointed to find that to build a project - all of the components I have no interest is still need to be compiled.
I request that the MenuConfig process provide a simple component selection page -- there by making builds faster and easier to find where one component may be dependent on another component's build.
Is there a way in the short term to address this?
What if I just removed the component folders thereby negating that part of the build? Not a long term solution because it does not allow component selection by project.
Joe
Re: Request for new IDF based development
Postby AgentSmithers » Sat Sep 29, 2018 1:51 am
What Operating System? I didn't know an IDE was released by Espressif or are you talking about the Visual Studio integration?
jhinkle
Postby jhinkle » Sat Sep 29, 2018 2:39 am
I'm doing development in Windows7.
The ESP8266-RTOS-IDF is not formally released but here is a git for the latest work being done.
https://github.com/espressif/ESP8266_RTOS_SDK/tree/release/v3.0
I have a LWIP issue using the binary-blob ESP8266-Rtos V2.0 so I'm attempting to port my project over to the new IDF which gives me complete control over the LWIP implementation.
As a side note -- I implemented ESP32-IDF development on Windows using Visual Studio -- see link below.
I removed the global ENV variable IDF_PATH and added an export line to each of my ESP32 or ESP8266 projects so that the variable IDF_PATH points to the proper location.
End result -- a nice Windows development for all ESP products now.
https://www.youtube.com/watch?time_continue=147&v=VPgEc8FUiqI
Postby AgentSmithers » Sat Sep 29, 2018 5:21 am
Interesting. I'll have to give this a shot. News to me!
Users browsing this forum: Bing [Bot] and 10 guests
