Memory Leak/Usage
zaxl
Re: Memory Leak/Usage
Postby zaxl » Wed Aug 19, 2015 5:43 pm
If using v1.3.0 without SSL memory leak patch it does work with iot.espressif.cn.
If using v1.3.0 WITH SSL patch - it does work with stock v1.3.0 but doesn't work with ssl patch.
Works with ssl patch if i call secure_ca_enable after setting the buffer size.
espconn_secure_set_size(ESPCONN_CLIENT,SSLBUF);
secure_ca_enable(1,0x3d);
but if the call chain is in reverse doesn't work.
the above observations may be messed up since
now i see that you made changes on iot.espressif.cn
openssl s_client -connect iot.espressif.cn:443
Results in:
Verify return code: 20 (unable to get local issuer certificate)
I did the same on my server /removed the issuer certificate from the chain/ and the handshake went ok.
So seems the issue is with the issuer certificate verification.
zaxl
Postby ESP_Faye » Mon Aug 24, 2015 10:12 am
Please have a try with this new libssl, based on esp_iot_sdk_v1.3.0
libssl.zip
(151.31 KiB) Downloaded 348 times
zaxl
Postby zaxl » Mon Aug 24, 2015 2:49 pm
Hi, Faye!
Espressif_Faye wrote:Hi,
I'm sorry but it didn't work.
Test with only the server cert - OK
Test with server and issuer cert - Fail
But there is a little improvement - now it fails immediately - does not wait for server close.
zaxl
Postby ESP_Faye » Tue Aug 25, 2015 8:05 pm
There are two new APIs in the new lib that may help, please have a try.
zaxl
Postby zaxl » Tue Aug 25, 2015 8:29 pm
Hi, Faye!
If i got it right - tested with:
espconn_secure_cert_req_disable(3); // disable client certificates in server and client
The result is the same as the previous test.
I do not use client certificates /but it's a very welcome addition!/ - i want to verify that the server i'm connected to is authentic.
May be an option to consider self signed certificates valid would help in my case.
zaxl
Postby ESP_Faye » Wed Aug 26, 2015 5:31 pm
Is the "https://ssl.test.com" your SSL server ? We can not access to it by browser.
What is the IP, port and CA cert of your SSL server?
espconn_secure_ca_enable(ESPCONN_CLIENT, CA_FLASH_ADDR); // flash sector which stored "esp_ca_cert.bin"
espconn_secure_cert_req_enable(ESPCONN_CLIENT, CERT_FLASH_ADDR); // flash sector which stored "esp_cert_private_key.bin"
espconn_secure_connect(&conn);
How to get "esp_ca_cert.bin", please refer to documentation "5A-ESP8266__SDK__SSL_User_Manual" in \esp_iot_sdk_v1.3.0\document, tools in \esp_iot_sdk_v1.3.0\tools.
How to get "esp_cert_private_key.bin", please refer to the attachment.
Certificate Request.zip
(1.9 MiB) Downloaded 375 times
zaxl
Postby zaxl » Thu Aug 27, 2015 8:54 pm
Hi, Faye!
Check your private messages about my server and ca cert details.
Having two scripts called make_cert.py is a bit confusing.
When acting as a client it doesn't make sense to have all the certs and keys issued merged -
so i used a simple
cat private.key certificate.key > esp_cert_private_key.bin
the script does exactly the same.
{ code }
int sect;
sect = 0x6b;
os_printf("cachain at %x\n", sect);
espconn_secure_ca_enable(ESPCONN_CLIENT, sect);
sect = 0x6c;
os_printf("client key at %x\n", sect);
espconn_secure_cert_req_enable(ESPCONN_CLIENT, sect);
{ end code }
cachain at 6b
client key at 6c
E:M 51440
Fatal exception (28):
epc1=0x4000e1e0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
/ 0x4000e1e0 is at pm_set_sleep_time but i'm not sure if i got it right /
zaxl
Postby ESP_Faye » Fri Aug 28, 2015 12:44 pm
zaxl
Postby zaxl » Fri Aug 28, 2015 1:23 pm
Hi, Faye!
No, i've send you the real server and both .bin files in a private message.
I see it is in my outbox and not in the send items.
Please, take a look.
zaxl
Postby ESP_Faye » Thu Sep 10, 2015 4:24 pm
Sorry that we only support ROOT CA, do not support Intermediate CA + root CA right now.
But your request is very important to us, we will think over it and support it in the future.
