DNS issues then IP Error when using CIPSTART with an IP address
clarksn
Postby clarksn » Mon Mar 12, 2018 4:56 am
I'm using AT+CIPSTART to establish a TCP link and my error trapping picked up quite a few fails and on expanding my debugging I discovered I seemed to be getting quite a few DNS fails for no apparent reason (can typically take 10-15 seconds or so for this error to be reported).
As a workaround I tried the IP address instead of the domain name but this immediately returns with an IP ERROR message. Although I was already on fairly current firmware I upgraded to AT Bin V1.6.1 but the symptoms are identical as the slightly earlier firmware.
The problem is reproducible on several different Arduinos including those with an ESP-01 and those with a Wemos Arduino Mega with integral 8266 flashed with the above firmware.#
Any ideas on both the DNS issue and the fact that substituting the server name with a pre-resolved IP fails immediately with an IP ERROR message?
thanks
Re: DNS issues then IP Error when using CIPSTART with an IP address
Postby Her Mary » Tue Mar 20, 2018 6:05 pm
Which IP address you used? An AT log list will be very helpful for debugging.
kreakemp
Postby kreakemp » Thu Apr 18, 2019 12:20 am
I am also facing same issue. Please help me regarding this. The server is running fine but can't able to connect.
Here is the command sequence that i have followed: (
(Time in milli Sec) (Command)
14487--> AT
14488-->
14489--> OK
29891--> AT+CWQAP
29892-->
29892--> OK
38195--> AT+CIPMODE?
38196--> +CIPMODE:0
38196-->
38197--> OK
170120--> AT+CWJAP="KreakEmp","kkpkkp123"
173322--> WIFI CONNECTED
174123--> WIFI GOT IP
175223-->
175224--> OK
183226--> AT+CIPMUX=0
183227-->
183228--> OK
188529--> AT+CIPMUX=1
188530-->
188530--> OK
213635--> WIFI DISCONNECT
219237--> WIFI CONNECTED
220238--> WIFI GOT IP
227940--> AT+CIFSR
227942--> +CIFSR:STAIP,"192.168.43.116"
227944--> +CIFSR:STAMAC,"ec:fa:bc:27:67:58"
227989-->
228003--> OK
256025--> AT+CIPSTART=1,"TCP","52.66.148.290",61234
259227-->
259227--> ERROR
259228--> 1,CLOSED
260630--> WIFI DISCONNECT
264032--> WIFI CONNECTED
266733--> WIFI GOT IP
Postby Her Mary » Tue Apr 23, 2019 11:16 am
Maybe you can try to ping the "52.66.148.290" firstly, to see if it can ping successfully.
