RTOS SDK 2.1 : Switch OFF the wifi without enter in sleep mode
ThierryC49
Postby ThierryC49 » Tue Jun 11, 2019 5:14 pm
I would like to switch OFF WiFi but still active the main MCU for survey process on some input and send alert by WiFi, is there any way to switch OFF the WiFi alone without entered in deepsleep mode
Thierry,
ThierryC49
Re: RTOS SDK 2.1 : Switch OFF the wifi without enter in sleep mode
Postby ThierryC49 » Wed Jun 12, 2019 11:57 pm
I post my self reply for other user (I found this information on espressif document 20a-esp8266_rtos_sdk_programming_guide_en.pdf page 28 :
to switch OFF the RF part
wifi_station_disconnect();
wifi_set_opmode(NULL_MODE);
wifi_set_sleep_type(MODEM_SLEEP_T);
wifi_fpm_open();
wifi_fpm_do_sleep(5*60*1000); //sleep for 1min
To switch ON the RF PART
wifi_station_connect();       // connect to AP
Please comment this post if you see any limitation or miss understanding from myself
Thierry,
Postby Her Mary » Wed Jun 26, 2019 11:24 am
Maybe you can try force modem sleep, modem sleep is only switch off the RF afaik.
void fpm_wakup_cb_func1(void)
   wifi_fpm_close();
void user_func()
wifi_fpm_set_sleep_type(MODEM_SLEEP_T);
wifi_fpm_open();
// wakeup automatically when timeout.
wifi_fpm_set_wakeup_cb(fpm_wakup_cb_func1); // Set wakeup callback
wifi_fpm_do_sleep(50*1000);
 #endif
