ESP8266 RTOS 3.2 GPIO example
hongwazi
Postby hongwazi » Wed Jul 03, 2019 10:32 pm
ESP8266_RTOS_SDK-3.2/examples/peripherals/gpio
保持代码不变:编译,程序可以运行
修改代码:
以前:
#define GPIO_OUTPUT_IO_0 15
#define GPIO_OUTPUT_IO_1 16
#define GPIO_OUTPUT_PIN_SEL ((1ULL<<GPIO_OUTPUT_IO_0) | (GPIO_OUTPUT_IO_1 ))
修改后:
#define GPIO_OUTPUT_IO_0 10
#define GPIO_OUTPUT_PIN_SEL ((1ULL<<GPIO_OUTPUT_IO_0))
最后会卡死在: gpio_config(&io_conf);
其内部其实卡死在:
WRITE_PERI_REG(GPIO_PIN_REG(io_num), pin_reg.val);
为什么呢?
Re: ESP8266 RTOS 3.2 GPIO example
Postby Her Mary » Fri Jul 05, 2019 5:25 pm
GPIO10 应该是被 flash 占用了,不能作为 GPIO 用吧
Users browsing this forum: Bryantpoirm, HenryCot, Henryionic and 5 guests
