How to guard time critical sections from RTOS interrupts?
Postby btomic » Thu Apr 05, 2018 6:15 am
The 1-wire bus is timing sensitive and some operations must not be interrupted. All sensitive portions of the code (which last for about 60 us) are guarded by the taskENTER_CRITICAL/taskEXIT_CRITICAL pair but the problem still occurs. It looks like that wifi interrupts are still interrupting critical sections and affecting critical timing on the 1-Wire bus.
I tried instead to guard critical sections with taskDISABLE_INTERRUPTS/taskENABLE_INTERRUPTS pair but the problem is still there. In this case the scheduler can still interrupt the critical sections. An attempt to both disable interrupts and use taskENTER_CRITICAL does not work at all.
Is there any way in ESP8266_RTOS_SDK to absolutely protect critical sections from high priority wifi interrupts (and still using the wifi)?
Re: How to guard time critical sections from RTOS interrupts?
Postby cranphin » Tue Jul 23, 2019 5:54 am
But this is not recommended :)
See also (for system task prio's): https://docs.espressif.com/projects/esp ... tasks.html
Postby cranphin » Sun Aug 11, 2019 10:21 pm
What does seem to work is including <xtensa/xtruntime.h>, and replacing taskENTER_CRITICAL/taskEXIT_CRITICAL with:
uint32_t savedLevel = XTOS_DISABLE_ALL_INTERRUPTS;
XTOS_RESTORE_INTLEVEL(savedLevel);
It does mostly the same (feel free to look at the source code, it's all in the SDK), except it disables all interrupt levels.
Of course this is probably very dangerous :)
It would be great if we could get a suggestion from Espressif on what the best approach would be here. I'm really not sure exactly what I'm doing here, and things like interrupts and their levels and what they do for WiFi are hardly well documented :)
I'm sure the official statement would be esp8266 is meant for WIFI, not accurate timing.
But what made the esp8266 so interesting for hobby projects is being able to do stuff like bit banging 1-wire temperature sensors, it would be nice if we could do that in the RTOS SDK too, since it seems to be getting the most love from Espressif at the moment :)
Ofcourse if someone there could get away with writing a good onewire driver as sample in the SDK, that would be even better ;)
Nice summer project? :D
Postby cranphin » Wed Aug 14, 2019 5:02 am
(At the same time, MQTT WiFi sends are running)
Task which runs the code:
const BaseType_t ret = xTaskCreate(ds_task,
"ds_task",
2048,
NULL,
// See https://docs.espressif.com/projects/esp8266-rtos-sdk/en/latest/api-guides/system-tasks.html for prio's
15, // Can't go higher, who cares about stable WiFi.
&ds_task_handle);
Includes/defines
#include <xtensa/xtruntime.h>
#include "esp8266/gpio_struct.h"
#include "freertos/task.h"
// At microsecond speeds, the functions from gpio.h are too heavy
#define GPIO_FAST_SET_1(gpio_num) GPIO.out_w1ts |= (0x1 << gpio_num)
#define GPIO_FAST_SET_0(gpio_num) GPIO.out_w1tc |= (0x1 << gpio_num)
#define GPIO_FAST_OUTPUT_ENABLE(gpio_num) GPIO.enable_w1ts |= (0x1 << gpio_num)
#define GPIO_FAST_OUTPUT_DISABLE(gpio_num) GPIO.enable_w1tc |= (0x1 << gpio_num)
#define GPIO_FAST_GET_LEVEL(gpio_num) ((GPIO.in >> gpio_num) & 0x1)
The method with the critical section
uint32_t IRAM_ATTR onewire_read_bit(void) {
uint32_t r;
GPIO_FAST_OUTPUT_ENABLE(ONEWIRE_PIN);
GPIO_FAST_SET_0(ONEWIRE_PIN);
ets_delay_us(3);
GPIO_FAST_OUTPUT_DISABLE(ONEWIRE_PIN);
ets_delay_us(10); // Somewhere near here, sometimes we still get 10us extra delay
r = GPIO_FAST_GET_LEVEL(ONEWIRE_PIN);
usleep(53);
return r;
Postby cranphin » Wed Aug 21, 2019 1:46 am
Users browsing this forum: Bryantpoirm, HenryCot, Henryionic, Majestic-12 [Bot] and 6 guests
