ESP8266 - GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
beegee1962
Postby beegee1962 » Mon Feb 01, 2016 5:33 pm
I was looking into a solution to send push notifications from an ESP8266 module to an Android application. I know that this is possible with the Google Cloud Messaging service.
But what I found on the internet is using an external webserver, able to run PHP (or Python) scripts and using a MySQL server to store registration IDs.
So far so good, but why do I need to setup an external server with MySQL and PHP just to send messages to the Android devices. The ESP8266 has server capabilities build-in and has enough storage to save registration IDs in the Flash memory.
What I wanted is:
As I could not find any tutorial or example on the Internet how to achieve this, I started to write the code by myself.
And here is the result:
ESP8266 - Google Cloud Messaging without external server
Of course the code is open source and stored in my Github repository
Hope it helps someone.
wuyunzhou
Re: ESP8266 - GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
Postby wuyunzhou » Tue Feb 02, 2016 5:17 pm
good job.
yes, if the device can get the gcm api_key, and the android registration id, the device can notify without server.
so the first is to pass the android registration id from app to device,
then make a http request to Gcm server, like this:
POST /gcm/send HTTP/1.1
User-Agent: curl/7.22.0 (x86_64-pc-linux-gnu) libcurl/7.22.0 OpenSSL/1.0.1 zlib/1.2.3.4 libidn/1.23 librtmp/2.3
Host: gcm-http.googleapis.com
Accept: */*
Authorization: key=${api_key}
Content-Type: application/json
Content-Length: xx
{"registration_ids":%s,"priority":"%s","time_to_live":%s,"data":%s}
registration_ids is a array with android registration ids.
beegee1962
Postby beegee1962 » Tue Feb 02, 2016 8:26 pm
wuyunzhou,
Correct, that is how it works. However I didn't use the "priority" and "time_to_live' keys.
JamesRit
ESP8266 GOOGLE CLOUD MESSAGING WITHOUT EXTERNAL SERVER
Postby JamesRit » Mon May 22, 2017 4:09 pm
Hi. copying the form of the sample in my test project, allways get the error google is not defined. I can run the sample avobe with no problem, but with my test project, allways the same error. I dont konw why. Thanks.
Tofd8lger
View first unread post
Postby Tofd8lger » Sun Nov 10, 2019 2:28 pm
I searched for fw20 and did not see anything that I was allowed to see, only one thing in the sale section or somthing which you need a post to view, so tada. Anyway, I have a fw20 deck and when you hit play on either side it usually spins but the left side of the tape just keeps getting eaten up, like maybe only on of the reels is spinning. anyone know how to fix this?
<a href=https://prom-electric.ru/>.</a>
