how to support the "captive Portal" on ESP8266
lijay910
Postby lijay910 » Sat Jul 28, 2018 5:10 pm
HI
use the code,such as:
LOCAL void ICACHE_FLASH_ATTR
user_udp_recv(void *arg, char *pusrdata, unsigned short length)
char DeviceBuffer[40] = {0};
char Device_mac_buffer[60] = {0};
char hwaddr[6];
struct espconn *pesp_conn = arg;
struct ip_info ipconfig;
at_port_print("user_udp_recv\r\n");
//at_port_print(pusrdata);
//m_pespconn =pesp_conn;
remot_info *premot = NULL;
sint8 value = ESPCONN_OK;
char pbuf[100] = {0};
if (espconn_get_connection_info(pesp_conn,&premot,0) == ESPCONN_OK){
pesp_conn->proto.tcp->remote_port = premot->remote_port;
pesp_conn->proto.tcp->remote_ip[0] = premot->remote_ip[0];
pesp_conn->proto.tcp->remote_ip[1] = premot->remote_ip[1];
pesp_conn->proto.tcp->remote_ip[2] = premot->remote_ip[2];
pesp_conn->proto.tcp->remote_ip[3] = premot->remote_ip[3];
os_sprintf(pbuf,"DNS Remote[IP=" IPSTR "][Port=%d]",IP2STR(&pesp_conn->proto.udp->remote_ip), pesp_conn->proto.udp->remote_port);
at_port_print(pbuf);
//espconn_sent(pesp_conn, pusrdata, os_strlen(pusrdata));
espconn_sent(pesp_conn, html, strlen(html));
but it is never usefull.
after to connet to the EPS82666 AP, but cann't show the portal window on the phone.
how to suport the captive Portal on esp8266??
andrelewis
Re: how to support the "captive Portal" on ESP8266
Postby andrelewis » Wed Oct 02, 2019 10:43 am
Interested.
annashetty
Postby annashetty » Fri Aug 14, 2020 11:34 am
There is a lot of good information driving directions
Jokovich
Postby Jokovich » Wed Nov 04, 2020 7:02 pm
Found a lot of useful information, glad to join your community. 192.168.1.1
192.168.1.254
