Help setting up ESP8266 RTOS SDK (xtensa not found error)?
ShaneKirkbride
Postby ShaneKirkbride » Wed May 04, 2016 1:18 am
I set up a virtual box that runs Lubuntu. I'm created the shared drive. I then pulled the RTOS SDK from the git hub. I moved the example/websocket_demo up one level.
I go to compile and I get this error:
make[1]: xtensa-lx106-elf-gcc: Command not found
make[1]: *** [.output/eagle/debug/obj/user_main.o] Error 127
make[1]: Leaving directory `/mnt/Share/ESP8266_RTOS_SDK/websocket_demo/user'
make: *** [.subdirs] Error 2
Here is a screen shot of what I'm doing
[img]
[/img]
I've added xtensa into my path and it exists in my /opt directory. I can't figure out how to make it recognize it so this will compile. Can anyone help me resolve this?
~Shane
Re: Help setting up ESP8266 RTOS SDK (xtensa not found error)?
Postby ESP_Faye » Tue May 10, 2016 10:15 am
It means that you do not have gcc in your PATH.
Here is the ESP8266 Getting Started Guide. You can follow the guide to setup the compiler.
ShaneKirkbride
Postby ShaneKirkbride » Thu Jun 16, 2016 6:29 am
Thanks for your help. I got it all worked out. I ended up using the open-sdk. It works pretty well. I have another issue trying to update the ESP with the FLAS Download too. That post is in a different thread.
~Shane
Users browsing this forum: Baidu [Spider] and 8 guests
