ESP8266 as TCP server
Postby ESP_Faye » Thu Jul 16, 2015 9:58 am
If using espconn in ESP8266_RTOS_SDK, please call espconn_init in user_init as initialization.
1. Start from user_init
2. ESP8266 is in station mode and connect to a router
3. Set up a TCP server listening to TCP client
4. If TCP server received data from TCP client, it will reply the same data back to TCP client.
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
#include "espconn.h"
LOCAL struct espconn esp_conn;
LOCAL esp_tcp esptcp;
#define SERVER_LOCAL_PORT   1112
 * FunctionName : tcp_server_sent_cb
 * Description  : data sent callback.
 * Returns      : none
LOCAL void ICACHE_FLASH_ATTR
tcp_server_sent_cb(void *arg)
   //data sent successfully
    os_printf("tcp sent cb \r\n");
 * FunctionName : tcp_server_recv_cb
 * Description  : receive callback.
 * Returns      : none
tcp_server_recv_cb(void *arg, char *pusrdata, unsigned short length)
   //received some data from tcp connection
   os_printf("tcp recv : %s \r\n", pusrdata);
   espconn_sent(pespconn, pusrdata, length);
 * FunctionName : tcp_server_discon_cb
 * Description  : disconnect callback.
 * Returns      : none
tcp_server_discon_cb(void *arg)
   //tcp disconnect successfully
    os_printf("tcp disconnect succeed !!! \r\n");
 * FunctionName : tcp_server_recon_cb
 * Description  : reconnect callback, error occured in TCP connection.
 * Returns      : none
tcp_server_recon_cb(void *arg, sint8 err)
   //error occured , tcp connection broke.
    os_printf("reconnect callback, error code %d !!! \r\n",err);
LOCAL void tcp_server_multi_send(void)
   struct espconn *pesp_conn = &esp_conn;
   remot_info *premot = NULL;
   uint8 count = 0;
   sint8 value = ESPCONN_OK;
   if (espconn_get_connection_info(pesp_conn,&premot,0) == ESPCONN_OK){
      char *pbuf = "tcp_server_multi_send\n";
      for (count = 0; count < pesp_conn->link_cnt; count ++){
         pesp_conn->proto.tcp->remote_port = premot[count].remote_port;
         pesp_conn->proto.tcp->remote_ip[0] = premot[count].remote_ip[0];
         pesp_conn->proto.tcp->remote_ip[1] = premot[count].remote_ip[1];
         pesp_conn->proto.tcp->remote_ip[2] = premot[count].remote_ip[2];
         pesp_conn->proto.tcp->remote_ip[3] = premot[count].remote_ip[3];
         espconn_sent(pesp_conn, pbuf, os_strlen(pbuf));
 * FunctionName : tcp_server_listen
 * Description  : TCP server listened a connection successfully
 * Returns      : none
tcp_server_listen(void *arg)
    struct espconn *pesp_conn = arg;
    os_printf("tcp_server_listen !!! \r\n");
    espconn_regist_recvcb(pesp_conn, tcp_server_recv_cb);
    espconn_regist_reconcb(pesp_conn, tcp_server_recon_cb);
    espconn_regist_disconcb(pesp_conn, tcp_server_discon_cb);
    espconn_regist_sentcb(pesp_conn, tcp_server_sent_cb);
   tcp_server_multi_send();
 * FunctionName : user_tcpserver_init
 * Description  : parameter initialize as a TCP server
 * Parameters   : port -- server port
 * Returns      : none
user_tcpserver_init(uint32 port)
    esp_conn.type = ESPCONN_TCP;
    esp_conn.state = ESPCONN_NONE;
    esp_conn.proto.tcp = &esptcp;
    esp_conn.proto.tcp->local_port = port;
    espconn_regist_connectcb(&esp_conn, tcp_server_listen);
    sint8 ret = espconn_accept(&esp_conn);
    os_printf("espconn_accept [%d] !!! \r\n", ret);
LOCAL os_timer_t test_timer;
 * FunctionName : user_esp_platform_check_ip
 * Parameters   : none
 * Returns      : none
user_esp_platform_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    os_timer_disarm(&test_timer);
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0) {
      os_printf("got ip !!! \r\n");
      user_tcpserver_init(SERVER_LOCAL_PORT);
    } else {
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL)) {
         os_printf("connect fail !!! \r\n");
        } else {
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_esp_platform_check_ip, NULL);
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set  station mode
   // ESP8266 connect to router.
   user_set_station_config();
TCP_Server_Example_02.zip
This is another example of ESP8266 working as TCP server with multiple TCP connections.
(1.03 KiB) Downloaded 1668 times
PaulTsai111
Re: ESP8266 as TCP server
Postby PaulTsai111 » Wed May 18, 2016 10:46 am
Hi Espressif:
I used the sample code ESP8266 as TCP server , but after I compiling the code , it shows a lot of error messages.
what's wrong with it ? I do not know how to test that !
The codes and sim results are shown as attached files.
Dashaduamp
Postby Dashaduamp » Wed Jun 21, 2017 8:05 am
Dear Sir
I am Dushyant here
i have made Vb code for Modbus Tcp/Ip. Which works as Server/Slave as well as Client/Master.
Now my software can connect with only one server at one time
so is it possible to be connected for continusly with more then one server?
andreysnug
Postby andreysnug » Thu May 24, 2018 6:28 am
Hello ,
I have noticed some examples found in the help web page for wlan esp8266. One is the TCP server that a PC can connect the the esp8266 access point and switch on off LEDs.
The other is the TCP client that the esp8266 connects to home router and accesses matrixs web page.
Is there an example of those 2 combined?
It would be good to connect the esp8266 to home router and switch LEDs on off through the internet by enabling port forward on home router.
Thank you
Best Regards
Andreas Achilleos
bennieced
Postby bennieced » Tue Apr 23, 2019 10:38 pm
hi there, I can get this working great sending srings from Eventghost to my RTI controller, but cannot get it working back the other way sending strings from RTI to Eventghost, is that possible?
