GET /update?api_key doesn't return anything
squalo
Postby squalo » Sat Dec 21, 2019 6:09 am
i am using ESP8266 with STM32F4. I am trying to send data to thingspeak using
GET /update?api_key
command. I have to see
in my buffer before use
GET /update?api_key
command. And i can see
in my buffer. Then, i use these lines to send data:
sprintf(gidecekdeger,"GET /update?api_key=A0AISRD6SB8SKH4J&field1=%d\r\n",10);
HAL_UART_Transmit(&huart2, (uint8_t *)gidecekdeger,strlen(gidecekdeger), 500);
but these lines returns nothing. (i put a breakpoint, so i am sure that code reaches here)
where is my mistake?
Re: GET /update?api_key doesn't return anything
Postby Her Mary » Mon Dec 30, 2019 5:47 pm
annawoods
Postby annawoods » Wed Feb 12, 2020 12:38 pm
thank you Her Mary for your help
tia65
Postby tia65 » Tue Feb 25, 2020 11:18 pm
Her Mary wrote:Could this example help? https://bbs.espressif.com/viewtopic.php?f=61&t=560
I have tried this and I have to say that its working fine on my side :)
Thanks and keep providing help on this amazing platform!
