exception at 4000df2f (memcmp)
st0ff3r
Postby st0ff3r » Sat Nov 17, 2018 8:49 pm
reason=2 exccause=28 epc1=0x4000df2f epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000033 depc=0x00000000
anyone know why app.map contains both
PROVIDE (ets_memcmp, 0x400018d4)
and
PROVIDE (memcmp, 0x4000dea8)
are those not the same?
include/platform.h says
#define memcmp(a, b, c) os_memcmp(a, b, c)
my code is at https://github.com/nabovarme/MeterLogge ... pto.c#L109
YimingLi
Re: exception at 4000df2f (memcmp)
Postby YimingLi » Thu Sep 26, 2019 6:45 pm
First, memcmp() and os_memcmp()/est_memcmp() are de-facto the same from point of brom, since the implementation of ets_memcmp() is something like below:
int ets memcmp(void *addr1, void *addr2, size_t n)
memcmp(addr1, addr2, n);
#define os_memcmp ets_memcmp
Similar the case is memcpy() and os_memcpy()/ets_memcpy(). Therefore, if an exception occurs at an address inside/following memcpy(), it might be caused by a call of os_memcpy()/ets_memcpy().
Second, 0x4000df2f is a branch address neither by/inside memcmp() nor by/inside ets_memcmp(), But is an address related to memcpy() or ets_memcpy/os_memcpy() de-facto which is called.
1. 0x4000df2f is a branch address when the brom code memcpy(dest_addr, src_addr, length)/os_memcpy()/ets_memcpy() is called
2, Exception 28 caused at 0x4000df2f with excvaddr=0x00000033 indicates below:
(1) excvaddr=0x00000033 indicates that memcpy(dest_addr, src_addr, length) is called with src_addr=0x00000033, which is an address load prohibited.
(2) exception cause at 0x4000df2f indicates that memcpy(dest_addr, src_addr, length), or os_memcpy(), or ets_memcpy() is called with dest_addr of 2-byte aligned but not 4-byte aligned (e.g. dest_dest = 0x3fff2014), and the length >= 6.
So, please check your code with all memcpy() or os_memcpy() or ets_memcpy(), especially with those possible src_addr=0x33 and length>=6 (ignoring thoese calling with length=4 for an example), and dest_addr is 2-bytes aligned(ignore those calling with odd dest_addr or 4-byte aligned dest_addr).
Hope it would be helpful for you!
ALK8266WIFI Module Extends MCU Capabilities to Tranceive in an efective speed of 1+MBytes/s
English: https://www.ebay.com/itm/283536362871
中文: https://item.taobao.com/item.htm?id=576141575067
blubb
Postby blubb » Thu Mar 19, 2020 10:08 pm
Any news on this exception?
I keep getting it, too, sometimes when rebooting after an OTA update. Is there a way to find out what is at address 0x33?
I noticed other people having the same issues, e.g.
https://bbs.espressif.com/viewtopic.php?t=2934
https://bbs.espressif.com/viewtopic.php?t=5784
https://www.esp8266.com/viewtopic.php?p=83491
It even happens in Arduino:
https://www.bountysource.com/issues/554 ... ot-esp8266
https://www.gitmemory.com/issue/esp8266 ... /491462561
https://groups.google.com/forum/#!topic ... Te2T-ZhF-U
st0ff3r
Postby st0ff3r » Tue Mar 24, 2020 2:00 am
I think I solved the problem by replacing the malloc()'ed variable with a static one, so I guess in some (low memory) circumstances malloc() returns an invalid pointer.
st0ff3r
Postby st0ff3r » Tue Mar 24, 2020 2:06 am
blubb wrote:Any news on this exception?
does it only happens after reboot by system_restart() or also after power-on?
With sdk 3.0.3 I see some exceptions to after calling system_restart(), but I guess its normal? It does not happen randomly after power on at least.
blubb
Postby blubb » Tue Mar 24, 2020 3:15 am
It happens only after calling system_upgrade_reboot() but just BEFORE the actual reset.
The reason in my case seems to be a timer which can fire during this short moment. I check for WiFi disconnection regularly and since system_upgrade_reboot() disconnects, the timer then tries to reconnect...
Root cause may be something inside wifi_station_connect() calling memcpy() with invalid parameters. That would be a task for Espressif...
https://github.com/espressif/ESP8266_NO ... -602231845
As for system_restart() I am not sure (did not try that often enough). But my guess is, it's exactly the same (since the disconnect happens there, too).
st0ff3r
Postby st0ff3r » Tue May 19, 2020 2:35 am
it was a missing NULL check in esp-open-lwip/lwip/netif/etharp.c, function etharp_raw()
fixed here https://github.com/nabovarme/esp-open-l ... ff35ce1ada
blubb
Postby blubb » Thu May 21, 2020 3:03 pm
Is that the original code? I cannot use libmbedtls with this lwip version.
Users browsing this forum: No registered users and 17 guests
