ESP8266 Wizard 1.2.5 for Visual Studio 2015 with FlashTool and Intellisense
tirpitz
Re: ESP8266 Wizard 1.2.5 for Visual Studio 2015 with FlashTool and Intellisense
Postby tirpitz » Fri Jul 29, 2016 4:57 am
compile OK
Linking FAIL
section `.irom0.text' will not fit in region `irom0_0_seg'
1> collect2.exe: error: ld returned 1 exit status
ESP_Rubin
Postby ESP_Rubin » Fri Jul 29, 2016 6:41 pm
sorry, we never give the comile solution based on VS
Musher40
Problem for flashing with espTool
Postby Musher40 » Mon Sep 12, 2016 5:04 pm
Hello
I was a problem for flashing esp8266 with NodeMcu 0.9 so i modified esptool see
https://github.com/DonKinzer/esp_tool/issues/1 and
https://github.com/DonKinzer/esp_tool/issues/2.
Marco
Postby pratik » Mon Sep 12, 2016 6:55 pm
tirpitz wrote:compile OK
Linking FAIL
You could try to mark your functions as iCache functions instead of iRAM (default). In case of VS, if the standard Espressif SDK ICACHE_FLASH_ATTR does not work, you may try modifying the .ld files according to your requirement.
Musher40
Postby Musher40 » Fri Sep 30, 2016 5:02 am
hello
ESP8266 wizard is OK with visual studio community but only 30 days without licence.
Why ESP8266 wizard is not OK with visual studio express whereas atmel studio is ok.
It is a problem of installation or a problem of feature.
log:
30/09/2016 10:25:27 - Found installed product - Microsoft Visual Studio Express 2013 for Windows
30/09/2016 10:25:27 - Found installed product - Microsoft Visual Studio Express 2013 for Windows Desktop
30/09/2016 10:25:27 - Found installed product - Microsoft Visual Studio Express 2015 for Windows Desktop
30/09/2016 10:25:27 - Found installed product - Global Location
30/09/2016 10:25:27 - Found installed product - AtmelStudio
30/09/2016 10:25:28 - VSIXInstaller.NoApplicableSKUsException: This extension is not installable on any currently installed products.
in fact the licence for visual studio community is renewable after 3 months.
thank you
Marco
Postby pratik » Sun Oct 02, 2016 12:31 pm
Sorry but the setup wizard is not an Espressif solution. You will need to contact the person who developed it and request them to ensure compatibility with the VS community edition.
We can only help when you manually configure your toolchain or have issues with our hardware.
