升级SDK到2.0后不断重启应当如何解决?
wsptr
Postby wsptr » Thu Aug 04, 2016 12:36 am
把SDK升级到2.0,重新编译程序后生成的eagle.flash.bin烧到0x00000,eagle.irom0text.bin烧到0x40000,esp_init_data_default.bin烧到0x7C000,blank.bin烧到0x7E000。烧完后片子不断重启,并打印如下信息:
load 0x40100000, len 30984, room 16
tail 8
chksum 0x47
load 0x3ffe8000, len 968, room 0
tail 8
chksum 0x84
load 0x3ffe83d0, len 1856, room 0
tail 0
chksum 0xc9
csum 0xc9
E:M 830521632
E:M 831924384
E:M 831924384
E:M 831924384
E:M 831924384
E:M 831924384
E:M 831924384
rf_cal[0] !=0x05,is 0xFF
请问这个问题应当如何解决?
zaxl
Re: 升级SDK到2.0后不断重启应当如何解决?
Postby zaxl » Thu Aug 04, 2016 1:27 am
I'll guess that you haven't flashed blank.bin on your RF cal sector - see SDK 2.0 release notes
zaxl
wsptr
Postby wsptr » Thu Aug 04, 2016 9:19 pm
zaxl wrote:Hi,
I have already falshed blank.bin into flash, even I generated a file that is 1MB filled with 0xFF and flashed that in. But the issue is still there. I tried to flash an old version built on an erlier SDK, then flash the new one directly without blank.bin, it worked. Why this happen?
Thank you.
wawaii
Postby wawaii » Thu Aug 11, 2016 6:19 pm
楼主解决了吗?
我用1.5.4也遇到了同样的问题。
但相同的bin文件烧到nodeMCU的开发板上可以工作,在我们自制的板上就会出现这个问题。
haojinghuan
Postby haojinghuan » Fri Aug 12, 2016 3:05 pm
我也遇到这个问题了,我用mqtt下的历程,烧录,第一次运行正常,断电之后就一直不停输出大量乱码,不知道是复位还是什么。其余的例子下载都很正常。
ESP_Rubin
Postby ESP_Rubin » Fri Aug 12, 2016 3:45 pm
将eagle.irom0text.bin烧录地址改为0x10000试试
wsptr
Postby wsptr » Fri Aug 12, 2016 11:51 pm
这个问题解决了,原因是esp_init_data_default.bin和blank.bin烧的地址不对。这两个文件需要根据使用的Flash的大小确定烧写的位置。我的ESP8266外接的是1MB的Flash,所以esp_init_data_default.bin烧到0xFC000,blank.bin烧到0xFE000。另外eagle.irom0text.bin烧录地址确实应该是在0x10000,之后就一切正常了。
Users browsing this forum: Ropphosy and 13 guests
