math functions
ajay.bhargav
math functions
Postby ajay.bhargav » Sat Jul 18, 2015 5:23 am
Hi I need to use some math functions in my project but libm is not part of precompiled toolchain provided. So I compiled fresh toolchain from crosstool-NG available at github: https://github.com/jcmvbkbc/crosstool-NG I checked out branch lx106-g++. Toolchain compiled successfully. I can compile with libm now but... the linker reports error coz .text size has now increased > 0x8000
/opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.text' will not fit in region `iram1_0_seg'
I would like to know how can I use math functions? Are they available for ESP or not?
Re: math functions
Postby Her Mary » Mon Jul 20, 2015 5:27 pm
ajay.bhargav
Re: math functions
Postby ajay.bhargav » Mon Jul 20, 2015 11:42 pm
Thanks, I already have libm.a I compiled toolchain myself, I even tried the one you shared. But the problem is iram0 section getting overflowed > 0x8000 Which is the limit of ESP8266. I think simply compiling libm with application does not solve the problem. So I change the question... Is it possible to link libm.a symbols to irom0 section whereas rest of the section as it is.
I tried changing linker but nothing worked. I moved irom0.text to before .text section and added following:
 .irom0.text : ALIGN(4)
    _irom0_text_start = ABSOLUTE(.);
    *(.irom0.literal .irom.literal .irom.text.literal .irom0.text .irom.text)
    *(libm.a)
    *(libc.a)
    *(libgcc.a)
    _irom0_text_end = ABSOLUTE(.);
  } >irom0_0_seg :irom0_0_phdr
This does work and move all the symbols from .text to irom0 but application does not work at all.
I then tried:
    libm.a: *(.literal .text)
this did not work either.. so any suggestion to move libm to rom section??? anyone from Espressif team?
Ajay
Nikolay
Re: math functions
Postby Nikolay » Thu Jul 13, 2017 8:12 pm
That should be:
*libm.a:(.literal .text .literal.* .text.*)
works for me.
neilwalker
Re: math functions
Postby neilwalker » Thu Sep 24, 2020 7:45 pm
Nikolay wrote:
I'm using Crosstool-NG for my projects too. The last release was in Apr 13, 2019, but it's still a good toolchain generator. I'm a student at Tsinghua University and it helps me write my essays online lab reports and assignments.
What are some modern alternatives of a Crosstool-NG toolchain generator? I'm facing an error: "GAS does not know what format to use for target arm-linux-gnueabihf" when trying to build cross-compiler with the git version of crosstool-ng. Thanks.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 7 guests
