true maximum throughput[Done]
Franco La Paz
Postby Franco La Paz » Thu May 19, 2016 9:33 am
I write to ask about the maximum speed of transmission and reception reaching the ESP8266 in stream mode.
From already thank you very much and I apologize if this is not the right place for the question.
Franco La Paz
Re: true maximum throughput
Postby ESP_Faye » Tue Jun 07, 2016 2:40 pm
The throughput we tested with AT UART-WiFi passthrough mode is as below:
TCP Throughput: AT TCP passthrough Tx 303 Kbps; Rx 302Kbps @ baudrate 420000
UDP Throughput: AT UDP passthrough Tx 250 Kbps; Rx 250 Kbps @ baudrate 420000
newton123
Re: true maximum throughput[Done]
Postby newton123 » Thu Sep 01, 2016 1:34 pm
ESP_Faye, can you please give some details about your test procedure and which AT command firmware you are using in the ESP8266? We are trying to use WROOM-02 module with the AT command firmware but it is able to send 100KB data in about 50 secs only using a TCP connection to a TCP server. May I know how we can achieve that data rate?
barsznica
Postby barsznica » Thu Dec 21, 2017 11:40 am
Please? ;)
