spi_flash_write and / or spi_flash_read not work above 0x80000
Re: spi_flash_write and / or spi_flash_read not work above 0x80000
Postby ESP_Faye » Thu Jun 02, 2016 2:03 pm
Please select "32Mbit-C1" on the "Flash Size" area of the ESP Flash Download Tool, and download it again.
gustavo
Postby gustavo » Thu Jun 02, 2016 4:51 pm
It did work!
Could you explain please?
Is there a way to flash with these settings with esptool?
Or can I use this flash tool on Linux?
Postby ESP_Faye » Fri Jun 03, 2016 11:29 am
You can refer to the esptool on github https://github.com/themadinventor/esptool, it can set the corresponding flash size.
gustavo
Postby gustavo » Fri Jun 03, 2016 10:44 pm
You should also give an explanation about the problem or people will not know how to resolve similar issues.
At the very least point to some documentation which explains the difference.
Nonetheless I'm still having problems:
The following code:
void user_init(void)
    uint32 temp[4]={0x05, 0x06, 0x07, 0x08};
    uint32 temp1[4]={0};
    int l = 0x90000;
    printf("l: %d - 0x%x\n", l, l);
    int i = spi_flash_erase_sector(l);
    printf("spi_flash_erase_sector: %d\n", i);
    int o = spi_flash_write(l, temp, sizeof(temp));
    printf("spi_flash_write: %d\n", o);
    int p = spi_flash_read(l, temp1, sizeof(temp1));
    printf("spi_flash_read: %d\n", p);
    printf("read :0x%x, 0x%x, 0x%x, 0x%x\n", temp1[0], temp1[1], temp1[2], temp1[3]);
    uint32 temp2[4] = {0x01, 0x02, 0x03, 0x04};
    o = spi_flash_write(l, temp2, sizeof(temp2));
prints:
2nd boot version : 1.5
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 32Mbit(1024KB+1024KB)
jump to run user1 @ 1000
OS SDK ver: 1.4.0(c599790) compiled @ Mar  1 2016 17:25:17
SDK version:1.4.0(c599790)
l: 589824 - 0x90000
spi_flash_erase_sector: 0
spi_flash_write: 0
spi_flash_read: 0
read :0x1, 0x2, 0x3, 0x0
spi_flash_write: 0
spi_flash_read: 0
There's a 0x4 missing.
And If I try some other position, for example 0x250000
I get:
  SPI Speed      : 40MHz
  SPI Mode       : QIO
l: 2424832 - 0x250000
spi_flash_write: 0
spi_flash_read: 0
read :0x0, 0x0, 0x0, 0x0
spi_flash_write: 0
spi_flash_read: 0
And can't run the same code again without flashing:
ets_main.c
By my understanding, based on the 99c-esp8266_ota_upgrade_en_v1.6.pdf document, user data should go from 0x200000 to 0x3FC000.
Postby ESP_Faye » Tue Jun 07, 2016 1:34 pm
spi_flash_erase_sector(0x90); // Here should be the sector number 0x90
spi_flash_write(0x90000, temp, sizeof(temp)); // Here should be the flash address 0x90000
gustavo
Postby gustavo » Wed Jun 08, 2016 6:47 pm
Oh, right.
Thank you :)
