[Resolved]wifi_fpm_do_sleep crashes
tve
Re: wifi_fpm_do_sleep crashes
Postby tve » Wed Sep 23, 2015 11:46 pm
So wifi_fpm_set_wakeup_cb is a new function in the attached library? It wasn't documented in the SDK 1.4.0 Programming Guide?
You write "If ESP8266 entered the light sleep mode, it needs to be waked up via external GPIO", this is in contradiction to the SDK Programmng Guide description of wifi_fpm_do_sleep() (page 86) which states "Force ESP8266 enter sleep mode, and it will wake up automatically when time out."
Thanks!
tve
Postby tve » Thu Sep 24, 2015 12:04 am
The new library with the new wifi_fpm_set_wakeup_cb() call works, thanks!
JacksonLv
Re: [Resolved]wifi_fpm_do_sleep crashes
Postby JacksonLv » Fri Nov 02, 2018 11:47 am
hi,have you fixed this problem .I got same problem when enter light sleep mode
Users browsing this forum: Google [Bot] and 11 guests
