New FEATURES gathering
User avatar
rudi
Re: New FEATURES gathering
Postby rudi » Tue Nov 11, 2014 7:02 pm
on-die temp 'eratur' sensor ;-)
best wishes rudi ;-)
問候飛出去的朋友遍全球魯迪
User avatar
rudi
Postby rudi » Tue Nov 11, 2014 7:57 pm
hi espressif team
only a thinking about AES.
perhabs this will be nice future
likewise!..
loop AES
http://sourceforge.net/projects/loop-aes/
http://loop-aes.sourceforge.net/aespipe/
others: ( arduino ect )
https://github.com/qistoph/ArduinoAES256
http://www.literatecode.com/aes256
AES256 base function ( s-box? )
or/and
AES256 base function <-> prime / second spi s-box
best wishes
rudi
問候飛出去的朋友遍全球魯迪
Lars R.
Postby Lars R. » Tue Nov 11, 2014 8:43 pm
costaud wrote:Hey Guys, is there any special feature that would help a lot in your application?
Please , post your idea and suggestion here and the espressif guys will take them into consideration when designing the much more powerful soc-chip of the next generation.
+Pinout of package
. LNA on corner pin
. Power-pins on corner pins
. Power pins more together if possible (e.g. VDDA)
. IO-pins more together (e.g. CHIP_EN near OSC pins)
. OSC on corner pins (maintaining distance to power pins)
. RES12K on package, if possible
+Minimized wiring requirements for boot sequence; bootloader example:
. try UART boot with flash option; if fails -> try SPI flash boot; if fails -> try SDIO boot
+A second 4-bit SPI.
+Minimized library dependencies (source code of opensource projects)
Bigger changes:
+Bootloader on user-programmable FLASH (on-die/on-package)
+MBits of Flash on package
+Opensource microprocessor IP
Regards
Lars
costaud
Postby costaud » Wed Nov 12, 2014 7:46 pm
Wow!! Thanks a lot for your kind attention!!
guan
Postby guan » Wed Nov 26, 2014 12:00 am
I would like a timer/counter like the one you would find in a modern microcontroller. It would have a prescaler, can count from both internal clock and an external pin or interrupt (so I could use it for quadrature decoding, for example), usable for PWM output, trigger interrupts on overflow and compare (with multiple compare registers), and maybe trigger DMA if you implement that for other peripherals such as SPI or I2C.
muris
Contact:
Postby muris » Wed Nov 26, 2014 5:26 pm
I would also like to point out to "Trigger interrupts" - these are very important!
costaud
Postby costaud » Thu Nov 27, 2014 1:42 am
Roger that !
guan
Postby guan » Mon Dec 01, 2014 3:12 am
Pinout for the SPI flash (on the right-hand side of the chip) to match the standard pinout of SPI flash chips.
vowstar
Postby vowstar » Tue Dec 02, 2014 3:16 am
Sniffer mode in 802.11n
guan
Postby guan » Tue Dec 02, 2014 11:46 pm
Bootloader output should be 115200 baud (or something standard like 9600) instead of 75000 baud.
