ESP8266_RTOS_SDK V3.0 using IDF Menu Request
jhinkle
Postby jhinkle » Sun Sep 30, 2018 12:14 am
I request that the SSL option have a menu selection of "None"
Currently you must select MBED, AX, or Wolf - default being MBED
I went in and modified the generated sdkconfig file and removed the "y" from MBED but on compiling - conf.exe ran from the tools/kconfig folder.
I request your kconfig process allow for a "SSL None ". Why configure and compile a library that is not needed or wanted.
Thanks for your work in the area.
Users browsing this forum: Google [Bot] and 11 guests
