[SDK Release] ESP8266_NONOS_SDK_V1.5.3.1
Postby ESP_Faye » Mon Jun 06, 2016 8:02 pm
ESP8266_NONOS_SDK_V1.5.3.1_16_06_06 Release
Important Links
Here are the links for this SDK release (version ESP8266_NONOS_SDK_V1.5.3.1_16_06_06 ):
  2. Bug Bounty Program
Release Notes
This is a middle version solved some bugs based on ESP8266_NONOS_SDK_V1.5.3.
  1. The return value of system_adc_read is wrong.
  2. The current is too high in light sleep mode.
  3. Optimized igmp to solve the issue that the ESP8266 maybe reset if connected to a special router.
AT_v1.0.0 Release Note:
Notice:
Optimization:
  1. Optimized the behavior of writing Flash.
Have fun!
ESP8266_NONOS_SDK_V1.5.3.1_16_06_06发布
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP8266_NONOS_SDK_V1.5.3.1_16_06_06):
  1. 文档下载链接
  2. 您可以继续参与 Bug Bounty 计划
发布说明
这是一个中间版本的 ESP8266_NONOS_SDK,基于 ESP8266_NONOS_SDK_V1.5.3 解决了以下问题。
修正问题(符合乐鑫 Bug 赏金计划):
  1. system_adc_read 返回值异常。
  2. light sleep 模式下电流较高。
  3. 修正 igmp 解决 连接特殊路由器可能导致系统重启的问题。
AT_V1.0.0 Release Note:
注意:
AT_v1.1 更新说明:
优化:
  1. 优化 AT 固件写 Flash 的行为。
ESP8266_NONOS_SDK_V1.5.3.1_16_06_06.zip
(3.13 MiB) Downloaded 893 times
ESP_Stanza
Re: [SDK Release] ESP8266_NONOS_SDK_V1.5.3.1
Postby ESP_Stanza » Mon Jun 06, 2016 8:28 pm
提请注意,这并不是最新版本的SDK,而是基于V1.5.3版本优化后计划量产模组的固件版本。
v1.5.4已经发布,v1.5.3.1固件版本内的功能都已经包含在1.5.4中。
通常我们将在发布最新版本1个月后决定是否量产此固件版本。
Notice:
This is not the latest SDK, but an SDK version we plan to pre-store in ESP-WROOM-02 in future, based on v1.5.3.
All features in this version are included in v1.5.4.
Usually we will decide whether we will mass produce this version, after we have released this version for more than one month.
