[ESP8266] Station mode: Scan for routers
Postby ESP_Faye » Sat Feb 28, 2015 11:24 am
Sample code below is based on ESP8266_NONOS_SDK.
ESP8266 init with station mode, then it can scan routers nearby.
 * FunctionName : scan_done
 * Description  : scan done callback
 * Parameters   :  arg: contain the aps information;
                          status: scan over status
 * Returns      : none
void ICACHE_FLASH_ATTR
scan_done(void *arg, STATUS status)
  uint8 ssid[33];
  char temp[128];
  if (status == OK)
    struct bss_info *bss_link = (struct bss_info *)arg;
    while (bss_link != NULL)
      os_memset(ssid, 0, 33);
      if (os_strlen(bss_link->ssid) <= 32)
        os_memcpy(ssid, bss_link->ssid, os_strlen(bss_link->ssid));
      else
        os_memcpy(ssid, bss_link->ssid, 32);
      os_printf("(%d,\"%s\",%d,\""MACSTR"\",%d)\r\n",
                 bss_link->authmode, ssid, bss_link->rssi,
                 MAC2STR(bss_link->bssid),bss_link->channel);
      bss_link = bss_link->next.stqe_next;
  else
     os_printf("scan fail !!!\r\n");
 * FunctionName : user_scan
 * Description  : wifi scan, only can be called after system init done.
 * Parameters   :  none
 * Returns      : none
user_scan(void)
   if(wifi_get_opmode() == SOFTAP_MODE)
     os_printf("ap mode can't scan !!!\r\n");
     return;
   wifi_station_scan(NULL,scan_done);
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set softAP + station mode
   // wifi scan has to after system init done.
   system_init_done_cb(user_scan);
If you want to scan a specific AP, for example, scan an AP of which SSID is "ESP8266". You only need to set the value of parameter "SSID" in structure "scan_config" when calling wifi_station_scan.
user_scan(void)
     return;
   struct scan_config config;
   os_memset(&config, 0, sizeof(config));
   config.ssid = "ESP8266";
   wifi_station_scan(&config,scan_done);
Tofd8lger
ESP8266 Station mode Scan for routers
Postby Tofd8lger » Wed Sep 25, 2019 11:30 am
Well they pretty much all do the same but how about the Civ Ship Parts station in District 07 of HoL. No stuuter in Station scan mode is the exception rather than the rule for me.
