Enter Light Sleep Mode cause reset
JacksonLv
Postby JacksonLv » Fri Nov 02, 2018 11:42 am
I'm trying out to enter light sleep mode in a timer interrupt function,but it will crash and reset as it do sleep sometimes.I found when it is in smart config mode ,it won't crash.If it's in station mode and connected to the AP,it will have this matter.Here is my code and log ,PLS help!! MY SDK version is NONOS 3.0.0
sleep_time_cnt: 60
enter sleep mode
wifi disconnected
pm close 7
fpm open,type:1 0
fpm 758
load 0x40100000, len 2408, room 16
tail 8
chksum 0xe5
tail 8
chksum 0x84
load 0x3ffe8310, len 632, room 0
tail 8
chksum 0xd8
csum 0xd8
   void ICACHE_FLASH_ATTR user_init(){
   PIN_FUNC_SELECT(RED_LIGHT_IO_MUX, RED_LIGHT_IO_FUNC);
   drv_Switch_Init();
   sleep_init();
   os_printf("Firmware Version: 20181101\n");
   wifi_station_get_config_default(&stationConf);
   if (os_strlen(stationConf.ssid) != 0) {
      os_printf("user_scan\n");
      //net_status   = 1;
      os_timer_disarm(&check_ip_timer);
      os_timer_setfn(&check_ip_timer, (os_timer_func_t *) user_check_ip, NULL);
      os_timer_arm(&check_ip_timer, 100, 0);
   } else {
       os_printf("smartcfg\n");
       smartconfig_start(smartconfig_done);
       net_status  = 0;
       WIFI_DISCONNTED_FLAG;
   os_timer_disarm(&light_status_timer);
   os_timer_setfn(&light_status_timer, (os_timer_func_t *)led_status_timer_func , NULL);
   os_timer_arm(&light_status_timer,MAIN_TIMER_PERIOD,1);
   os_timer_disarm(&sleep_timer);
   os_timer_setfn(&sleep_timer, (os_timer_func_t *)sleep_timer_func , NULL);
   os_timer_arm(&sleep_timer,SLEEP_TIMER_PERIOD,1);
void sleep_init(void){
   wifi_fpm_set_sleep_type(LIGHT_SLEEP_T);     //set force sleep type, clsoe rf&cpu
   wifi_fpm_set_wakeup_cb(fpm_wakup_cb_func1); //Set fpm wakeup callback function
void sleep_start(void )
   os_printf("enter sleep mode\n\n");
   if(wifi_station_get_connect_status() == STATION_GOT_IP){
      while(!wifi_station_disconnect()){
         os_delay_us(10);
      os_printf("wifi disconnected\n\n");
   } else {
      smartconfig_stop();
      os_printf("wifi not connected\n\n");
   os_delay_ms(200);
   RED_LIGHT_OFF;
   wifi_set_opmode(NULL_MODE);               //set wifi mode to null mode.
   wifi_fpm_open();                        //enable force sleep fucntion
   int rst =  wifi_fpm_do_sleep(FPM_SLEEP_MAX_TIME);      // do sleep
   os_printf("sleep rst : %d",rst);
sleep_timer_func(void )
   static uint8_t cnt = 0;
   if(sleep_time_cnt < SLEEP_TIME_CNT){
      sleep_time_cnt++;
      os_printf("sleep_time_cnt: %d\n\n",sleep_time_cnt);
   }else {//2 min
      sleep_time_cnt = 0;
      os_timer_disarm(&KeyScan_timer);
      sleep_start();
Users browsing this forum: Google [Bot] and 4 guests
