Dead ESP
User avatar
rudi
Re: Dead ESP
Postby rudi » Sat Jul 30, 2016 1:28 am
scargill wrote:
..a couple of people wrote into me to say they had killed their boards....
.. I tried the same on 3 new boards of my own - and killed all three...
R.I.P.
:D
do not play with protected area on flash - this is no bug - this is a future -
for more detail, ask your WINBOND dealer.
FYI: if you have the wrong sequence, you kill ( protect ) the flash.
if killed ( protected ) then you can not ( writeable & saved ) flash on this area.
if firmware use protection user key and they crash with RBOOT configs,
then rboot can not boot on the sequence; and if you have the wrong sequence
you can flash new - but your firmware was not written totally - cause -
you have protected area - that can not overriden. ( user key, config key, orig firmware )
please, read data sheets
for I2C Theme: -> I2C
for extended future function -> winbond
then this would help you to understand how you must going on in the future
also, use the search function on the forum,
i have wrote moretimes about protection and firmware protection.
there are possibles ways.
-> protection area on flash
-> protection area on µSDHC ( SDIO ) ..
.. if you boot from µSDHC or load Firmware from µSDHC with combined RBOOT.
you can use a catalog of firmware, that RBOOT can boot/load by reference from µSDHC.
regards..
問候飛出去的朋友遍全球魯迪
SpenZerX
Contact:
Re: Dead ESP
Postby SpenZerX » Wed Aug 03, 2016 5:49 pm
scargill wrote:It LOOKs like it was not RBOOT after all..
2. After my initialisation of ports - and other stuff - I finally called a routine to do with WIFI....
wifi_set_opmode(0);
and that was fine until SDK 1.54 - after that - I'm getting no serial output (other than the 78k startup stuff) UNTIL that function is called.
May be you should not use wifi_set_opmode(0); in start up code, because it will do a flash write of settings.
luis_filipe
Re: Dead ESP
Postby luis_filipe » Thu Aug 04, 2016 10:28 am
Hello guys,
sorry for not open a new topic, but I cannot.
Anyway, i would like to ask who can I fix this error:
Sketch uses 221,995 bytes (51%) of program storage space. Maximum is 434,160 bytes.
Global variables use 31,568 bytes (38%) of dynamic memory, leaving 50,352 bytes for local variables. Maximum is 81,920 bytes.
C:\Users\root\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd ck -cb 115200 -cp COM6 -ca 0x00000 -cf C:\Users\root\AppData\Local\Temp\buildde9605d9d67ae2595f4f5b9646f4a46e.tmp/firstConnection2.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
   setting board to ck
   setting baudrate from 115200 to 115200
   setting port from COM1 to COM6
   setting address from 0x00000000 to 0x00000000
   espcomm_upload_file
   espcomm_upload_mem
   setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
   flush start
   setting serial port timeouts to 1 ms
   flush complete
   espcomm_send_command: sending command header
   espcomm_send_command: sending command payload
   serialport_receive_C0: BB instead of C0
trying to connect
   flush start
   flush complete
   serialport_receive_C0: 36 instead of C0
trying to connect
   flush start
   flush complete
resetting board
trying to connect
   flush start
   flush complete
trying to connect
   flush start
   flush complete
trying to connect
   flush start
   flush complete
   serialport_receive_C0: 32 instead of C0
resetting board
trying to connect
   flush start
   flush complete
   serialport_receive_C0: B3 instead of C0
trying to connect
   flush start
   flush complete
trying to connect
   flush start
   flush complete
   serialport_receive_C0: B7 instead of C0
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
I cannot upload any sketch from arduino IDE and when I open the serial monitor I only see garbage.
Who can I do to fix this problem?
Thanks in advance
