ESP8285 cannot run into user.bin sometimes
Nicholas3388
Postby Nicholas3388 » Thu Nov 15, 2018 6:13 pm
Hi, My ESP8285 sometimes cannot run into user2.bin when the firmware is upgraded via FOTA. The logs are as follow:
ets Jan 8 2013,rst cause:2, boot mode:(3,0)
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DOUT
jump to run user2 @ 81000
c炸A*蚯ny+EhQ贻?kt況嚝 栩?*蜈G1況猼@*r鸔?11)&?11)&?
t鸔?11??11?@猂jrA(!婼藂嬓汌沊薗鷁蔘*薗K↖*E??)dP沎隥A??E"HhI蜛,鬧Mor,R??┰vA?5y*e?n?U"HhI蜛,Z[MoR R?
5?癃A?5?U?n?EHhi預 P[M忽A,P[I 峇(龐P嘙鷔!B=d)奠=a€ j吼?e??%謵[闑-暶?敳機-Aea*U菼,怵徹Em楸{郲歗
1A韡氁讈(11堷c請A*蚯nY+EHq曩?Kt汻嚝 栩韁0*蜈G1涷?)&?11)&?111)&?T跶?1)勻1110\0
As you can see from the logs, the system is about to jump to user2, and then crash immediately and stop running. When I reboot the device by pressing the reset button manually, it will run without problem. This issue happen sometimes. Is there anyone know how to handle this issue?
Re: ESP8285 cannot run into user.bin sometimes
Postby Her Majesty » Tue Dec 11, 2018 8:45 pm
The same user2.bin, sometimes it runs successfully, sometimes it fails? Maybe the log of success running can tell something.
Postby AgentSmithers » Thu Dec 13, 2018 4:54 am
Are you running Firmware over the air?
