Compiling rtos sdk idf project with CMake
Re: Compiling rtos sdk idf project with CMake
Postby Deous » Mon Mar 16, 2020 11:28 am
I just installed Toolchain 1.0 and worked fine. When I installed the newest esp32 Toolchain 2.2 that includest newest Python - the idf.py would error on some missing paths and some other things with complex projects like f.ex. with protocols
Can you tell the steps of your toolchain installation in details ? Thanks
Postby mriksman » Mon Mar 16, 2020 1:25 pm
These are my notes;
For ESP-IDF pre 4.0 and ESP RTOS SDK v3.x, you’ll need to supply a prebuilt binary called mconf-idf. Place the files in esp8266\ESP8266_RTOS_SDK\tools
Install Git For Windows
Install Python 3.x (ESP-IDF makes a note that their may be issues with 3.x and to use 2.7)
Install CMake For Windows
When the installer asks for Install Options, select ‘Add CMake to the system PATH for the current user’.
Download Ninja
Extract the executable file to the bin folder within CMake.
As CMake is now in the PATH environment variable, you won’t have to add another PATH.
Download the Toolchain
ESP-IDF https://dl.espressif.com/dl/xtensa-esp32-elf-gcc8_2_0-esp-2019r2-win32.zip
ESP8266 https://dl.espressif.com/dl/xtensa-lx106-elf-win32-1.22.0-100-ge567ec7-5.2.0.zip
Create a folder called esp32 (or esp8266)
Extract xtensa-esp32-elf (or xtensa-lx106-elf) folder into it.
Download the SDK
Open PowerShell and navigate to the esp32/esp8266 folder.
Run
git clone --recursive https://github.com/espressif/esp-idf.git
git clone --recursive https://github.com/espressif/ESP8266_RTOS_SDK.git
The folder structure will look like this
esp32 esp8266
|-- esp-idf |-- ESP8266_RTOS_SDK
└-- xtensa-esp32-elf └-- xtensa-lx106-elf
Install the Python dependencies
pip install -r "path\to\esp32\esp-idf\requirements.txt"
Postby krankins » Thu Aug 06, 2020 6:48 pm
I was able to use only toolchain 1.0 (Windows 10) with Python 2.7
Postby handoi » Fri Oct 02, 2020 4:03 pm
Thanks. I finally downloaded both SDKs and Toolchains and configured VSCode. SO much better than PlatformIO (which uses ESP8266 RTOS 1.5). It's great being able to have code that can be (almost) reused on both chips.
The sooner Espressif roll BOTH ESP8266 and ESP32 into a single IDF, the better! run 3
spiceagent11
Postby spiceagent11 » Sat Dec 11, 2021 6:39 am
I am still facing the same issue
