Ehternet
stokersoft
Ehternet
Postby stokersoft » Wed Jun 05, 2019 2:47 pm
Do you plan to make an ethernet module very similar to Wroom02 with similar AT command set? It would be very nice.
We have looked at some other solutions, but till now we did not found one that could:
1, Run TCP on one socket
2. Run UDP on another socket simultanously
3. Read the UDP header (source ip and port) - the modules we examined only respons to the last client that it received a request from.
The last step is very important, if you have multiple simultaneosly clients connecting, or you will mix up the responses.
Regards Jens
Re: Ehternet
Postby Her Mary » Wed Jun 26, 2019 10:50 am
It seems that ESP8266 does not support Ethernet, maybe you can try ESP32 instead.
Users browsing this forum: No registered users and 21 guests
