ESP8266 Wizard 1.3.0 OpenSource for Visual Studio 2013, 2015 & 2017 with FlashTool, Intellisense and VIDEO Tutorial
daun
Re: ESP8266 Wizard 1.2.9 OpenSource for Visual Studio 2013, 2015 & 2017 with FlashTool, Intellisense and VIDEO Tutorial
Postby daun » Thu Mar 22, 2018 6:49 pm
I use visual studio with version like this:
Microsoft Visual Studio Community 2017
Version 15.6.3
Microsoft .NET Framework
Version 4.7.02556
When I install ESP8266 Wizard 1.2.9 - OpenSource (1.0).exe, I get error like this:
22/03/2018 17.15.17 - Microsoft VSIX Installer
22/03/2018 17.15.17 - -------------------------------------------
22/03/2018 17.15.17 - vsixinstaller.exe version:
22/03/2018 17.15.17 - 15.0.26228.9 built by: D15RTWSVC
22/03/2018 17.15.17 - Command line parameters:
22/03/2018 17.15.17 - C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\VSIXInstaller.exe,C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\ESP8266Wizard.vsix
22/03/2018 17.15.18 - Initializing Install...
22/03/2018 17.15.19 - Extension Details...
22/03/2018 17.15.19 - Identifier : ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702
22/03/2018 17.15.19 - Name : ESP8266Wizard
22/03/2018 17.15.19 - Author : Mathieu St-Laurent - Rev OpenSource
22/03/2018 17.15.19 - Version : 1.2.9
22/03/2018 17.15.19 - Description : Create an ESP8266 C Project from SDK/Example or Blank Project
22/03/2018 17.15.19 - Locale : en-US
22/03/2018 17.15.19 - MoreInfoURL :
22/03/2018 17.15.19 - InstalledByMSI : False
22/03/2018 17.15.19 - SupportedFrameworkVersionRange : [4.5,)
22/03/2018 17.15.19 - SignatureState : Unsigned
22/03/2018 17.15.19 - Supported Products :
22/03/2018 17.15.19 - Microsoft.VisualStudio.Community
22/03/2018 17.15.19 - Version : [11.0,16.0)
22/03/2018 17.15.19 - References :
22/03/2018 17.15.19 - Prerequisites :
22/03/2018 17.15.19 - -------------------------------------------------------
22/03/2018 17.15.19 - Identifier : Microsoft.VisualStudio.Component.VC.CoreIde
22/03/2018 17.15.19 - Name : Fonctionnalités de base C++ de Visual Studio
22/03/2018 17.15.19 - Signature Details...
22/03/2018 17.15.19 - Extension is not signed.
22/03/2018 17.15.19 - Searching for applicable products...
22/03/2018 17.15.19 - Found installed product - Global Location
22/03/2018 17.15.19 - Found installed product - Visual Studio Community 2017
22/03/2018 17.15.20 - PKGDEF Information: Looking for master PkgDef file, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\master.pkgdef
22/03/2018 17.15.20 - PKGDEF Information: Creating PkgDefCacheNonVolatile
22/03/2018 17.15.20 - PKGDEF Information: Double-checking master pkgdef file
22/03/2018 17.15.20 - PKGDEF Information: PkgDefManagement initialized
22/03/2018 17.15.20 - PKGDEF Information: RootFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\
22/03/2018 17.15.20 - PKGDEF Information: ShellFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\
22/03/2018 17.15.20 - PKGDEF Information: PkgDefSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\CommonExtensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\devenv.admin.pkgdef
22/03/2018 17.15.20 - PKGDEF Information: ImageManifestSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\CommonExtensions;C:\Users\tauhid\AppData\Local\Microsoft\VisualStudio\15.0_b15249ee\Extensions
22/03/2018 17.15.20 - PKGDEF Information: ApplicationExtensionsFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\Extensions
22/03/2018 17.15.20 - PKGDEF Information: "ZeroImpact" = dword:0, "MergeRegistry" = dword:3
22/03/2018 17.15.20 - PKGDEF Information: Could not find ConfigurationChanged timestamp., PKGDEF: 80070002
22/03/2018 17.15.20 - PKGDEF Information: User extensions enabled by setting, Path: HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\15.0_b15249ee\ExtensionManager\EnableAdminExtensions
22/03/2018 17.15.20 - PKGDEF Information: PkgDefCache flags, PKGDEF: 7001
22/03/2018 17.15.20 - PKGDEF Information: PkgDefManagement startup complete
22/03/2018 17.15.22 - The extension with ID 'ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702' is not installed to Visual Studio Community 2017.
22/03/2018 17.22.07 - The following target products have been selected...
22/03/2018 17.22.07 - Visual Studio Community 2017
22/03/2018 17.22.09 - Beginning to install extension to Visual Studio Community 2017...
22/03/2018 17.22.32 - Package Microsoft.Windows.UniversalCRT.Msu.8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.2,6.3)'.
22/03/2018 17.22.32 - Package Microsoft.Windows.UniversalCRT.Msu.81 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.3,6.4)'.
22/03/2018 17.25.09 - Install Error : Microsoft.VisualStudio.Setup.PackageFailureException: Package 'Microsoft.VisualStudio.SLNX.VSIX' failed to install
at Microsoft.VisualStudio.Setup.InstallOperation.Run(CancellationToken token)
at Microsoft.VisualStudio.Setup.Engine.RunOperation(InstallOperation installOperation, CancellationToken token, ExecuteAction action, ITelemetryOperation telemetryOperation)
at Microsoft.VisualStudio.Setup.Engine.RunCoreOperation(InstallOperation coreOperation, ExecuteAction action, ITelemetryOperation telemetryOperation, CancellationToken token)
at Microsoft.VisualStudio.Setup.Engine.Install(Product product, String destination, CancellationToken token)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.PerformSetupEngineInstall(InstallableExtensionImpl extension, Boolean installPerMachine, Boolean isPackComponent, IDictionary`2 extensionsInstalledSoFar, List`1 extensionsUninstalledSoFar, IInstalledExtensionList modifiedInstalledExtensionsList, IProgress`1 progress, InstallFlags installFlags, AsyncOperation asyncOp, IInstalledExtension& newExtension)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.InstallInternal(InstallableExtensionImpl extension, InstallFlags installFlags, IDictionary`2 extensionsInstalledSoFar, List`1 extensionsUninstalledSoFar, IInstalledExtensionList modifiedInstalledExtensionsList, AsyncOperation asyncOp, IProgress`1 progress)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.BeginInstall(IInstallableExtension installableExtension, InstallFlags installFlags, AsyncOperation asyncOp)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.InstallWorker(IInstallableExtension extension, InstallFlags installFlags, AsyncOperation asyncOp)
How to solve this problem? Thanks
rlivio
Postby rlivio » Tue Mar 27, 2018 12:44 am
Hi
I try to install on a PC with Windows 10 (just updated) and Visual Studio C++ Enterprise 2017, but I receive an error.
Can someone help me?
Thank you
Livio
26/03/2018 19:19:27 - Microsoft VSIX Installer
26/03/2018 19:19:27 - -------------------------------------------
26/03/2018 19:19:27 - vsixinstaller.exe version:
26/03/2018 19:19:27 - 15.0.26228.9 built by: D15RTWSVC
26/03/2018 19:19:27 - Command line parameters:
26/03/2018 19:19:27 - C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\VSIXInstaller.exe,C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\ESP8266Wizard.vsix
26/03/2018 19:19:27 - Initializing Install...
26/03/2018 19:19:27 - Extension Details...
26/03/2018 19:19:27 -    Identifier         : ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702
26/03/2018 19:19:27 -    Name               : ESP8266Wizard
26/03/2018 19:19:27 -    Author             : Mathieu St-Laurent - Rev OpenSource
26/03/2018 19:19:27 -    Version            : 1.2.9
26/03/2018 19:19:27 -    Description        : Create an ESP8266 C Project from SDK/Example or Blank Project
26/03/2018 19:19:27 -    Locale             : en-US
26/03/2018 19:19:27 -    MoreInfoURL        :
26/03/2018 19:19:27 -    InstalledByMSI     : False
26/03/2018 19:19:27 -    SupportedFrameworkVersionRange : [4.5,)
26/03/2018 19:19:27 -    SignatureState     : Unsigned
26/03/2018 19:19:27 -    Supported Products :
26/03/2018 19:19:27 -       Microsoft.VisualStudio.Community
26/03/2018 19:19:27 -          Version : [11.0,16.0)
26/03/2018 19:19:27 -    References         :
26/03/2018 19:19:27 -    Prerequisites      :
26/03/2018 19:19:27 -       -------------------------------------------------------
26/03/2018 19:19:27 -       Identifier   : Microsoft.VisualStudio.Component.VC.CoreIde
26/03/2018 19:19:27 -       Name         : Fonctionnalités de base C++ de Visual Studio
26/03/2018 19:19:27 - Signature Details...
26/03/2018 19:19:27 -    Extension is not signed.
26/03/2018 19:19:27 - Searching for applicable products...
26/03/2018 19:19:27 - Found installed product - Global Location
26/03/2018 19:19:27 - Found installed product - Visual Studio Enterprise 2017
26/03/2018 19:19:27 - PKGDEF Information: Looking for master PkgDef file, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\master.pkgdef
26/03/2018 19:19:27 - PKGDEF Information: Creating PkgDefCacheNonVolatile
26/03/2018 19:19:27 - PKGDEF Information: Double-checking master pkgdef file
26/03/2018 19:19:27 - PKGDEF Information: PkgDefManagement initialized
26/03/2018 19:19:27 - PKGDEF Information: RootFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\
26/03/2018 19:19:27 - PKGDEF Information: ShellFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\
26/03/2018 19:19:27 - PKGDEF Information: PkgDefSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\devenv.admin.pkgdef
26/03/2018 19:19:27 - PKGDEF Information: ImageManifestSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions;C:\Users\livio\AppData\Local\Microsoft\VisualStudio\15.0_b7b3e97f\Extensions
26/03/2018 19:19:27 - PKGDEF Information: ApplicationExtensionsFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions
26/03/2018 19:19:27 - PKGDEF Information: "ZeroImpact" = dword:0, "MergeRegistry" = dword:3
26/03/2018 19:19:27 - PKGDEF Information: Could not find ConfigurationChanged timestamp., PKGDEF: 80070002
26/03/2018 19:19:27 - PKGDEF Information: User extensions enabled by setting, Path: HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\15.0_b7b3e97f\ExtensionManager\EnableAdminExtensions
26/03/2018 19:19:27 - PKGDEF Information: PkgDefCache flags, PKGDEF: 7001
26/03/2018 19:19:27 - PKGDEF Information: PkgDefManagement startup complete
26/03/2018 19:19:28 - The extension with ID 'ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702' is not installed to Visual Studio Enterprise 2017.
26/03/2018 19:19:40 - The following target products have been selected...
26/03/2018 19:19:40 -    Visual Studio Enterprise 2017
26/03/2018 19:19:40 - Beginning to install extension to Visual Studio Enterprise 2017...
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.2,6.3)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.81 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.3,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.D3DCompiler.Msu.Win7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.FullRedist.NonThreshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.NET.4.6.FullRedist.NonThreshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.Debugger.DbgHelp.Win8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.Debugger.Remote.DbgHelp.Win8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.DiagnosticsHub.KB2882822.Win7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package WebSocket4NetV2 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.Threshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[10.0.10240]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.Threshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[10.0.10240]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.NonThreshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.NET.4.6.1.FullRedist.NonThreshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.81SDK.Store.DirectX.Msi is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Windows.81SDK.Desktop.DirectX.Msi is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.FullRedist is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.14393]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.FullRedist.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.14393]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.1.FullRedist is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.15063]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.1.FullRedist.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.15063]'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.OfficeDeveloperTools.WindowsIdentityFoundation.Msu is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '(,6.2)'.
26/03/2018 19:19:43 - Package 'Microsoft.VisualStudio.SLNX.VSIX,version=15.0.426.61103' failed to install. System.IO.IOException: The file 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions\Microsoft\OpenFolder\catalog.json' already exists.
   in Microsoft.VisualStudio.Setup.Installer.VsixInstaller.InstallCore(String localPath, String installDir, InstallablePackage pkg)
   in Microsoft.VisualStudio.Setup.Installer.InstallerBase.InstallHelper(InstallData installData)
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectServices,version=15.6.10.12453' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectServices,version=15.6.10.12453' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.ServiceHub,version=1.2.60.51671' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.ServiceHub,version=1.2.60.51671' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TeamExplorer,version=15.0.27509' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TeamExplorer,version=15.0.27509' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.TeamFoundation.OfficeIntegration.Resources,version=15.129.27509.11,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.TeamFoundation.OfficeIntegration,version=15.129.27509.11,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.TeamExplorer,version=15.129.27509.11' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TextMateGrammars,version=15.0.80116.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TextMateGrammars,version=15.0.80116.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.Build,version=15.6.82.30579,chip=neutral,language=neutral' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build,version=15.6.82.30579,chip=neutral,language=neutral' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build.FileTracker.Msi,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.Build.Dependencies,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build.Dependencies,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.DiaSymReader,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.DiaSymReader,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphProvider.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphProvider.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphProvider,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphProvider,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphModel.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphModel.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphModel,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphModel,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.PerformanceProvider,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PerformanceProvider,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Progression,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VirtualTree.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VirtualTree.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VirtualTree,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VirtualTree,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine.Resources,version=15.0.27005.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.WinXPlus,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.MSBuild.ARM,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VS.VC.MSBuild.X64.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Items.Pro.Resources,version=15.0.26208.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Items.Pro,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.DevCmd.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.DevCmd.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.DevCmd,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.DevCmd,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Core.DotNet,version=15.0.27019.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Core.DotNet,version=15.0.27019.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Core.WinSdk,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Core.WinSdk,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.VsDevCmd,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.UtilsPrereq,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.UtilsPrereq,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.CoreEditor,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Component.CoreEditor,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Workload.CoreEditor,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.MinShell.Interop.Msi,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Devenv.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Msi,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Msi.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.WebSiteProject.DTE.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.WebSiteProject.DTE.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.WebSiteProject.DTE,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.WebSiteProject.DTE,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Net.Eula.Resources,version=15.0.27205.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Net.Eula.Resources,version=15.0.27205.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.CollectorCab,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.CollectorCab,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.x64,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.x64,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.x86,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.x86,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.CommunityCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Enterprise.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Enterprise,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.EnterpriseCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Professional.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.ProfessionalCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.PackageGroup.ClientDiagnostics,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.DiagnosticsHub.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.DiagnosticsHub.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.DiagnosticsHub,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.DiagnosticsHub,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost.Targeted,version=15.6.27413.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost.Targeted,version=15.6.27413.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.MSVCDis,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.MSVCDis,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger,version=15.6.27428.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger,version=15.6.27428.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Managed.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Managed.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.ExpressionEvaluator.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.ExpressionEvaluator.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next.Resources,version=15.6.27309.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next.Resources,version=15.6.27309.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Managed,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Managed,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.CollectionAgents,version=15.6.27309.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.CollectionAgents,version=15.6.27309.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Parallel.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Parallel.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Parallel,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Parallel,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Common.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Common.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Common,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Common,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Debugger.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Debugger.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Debugger,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Debugger,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Debugger.Core,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TestTools.TeamFoundationClient.Resources,version=15.6.27428.2005,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TestTools.TeamFoundationClient.Resources,version=15.6.27428.2005,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TestTools.TeamFoundationClient,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TestTools.TeamFoundationClient,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.CodeSense,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.CodeSense,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Core,version=15.0.26906.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.MDD.Resources,version=15.0.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.MDD.Resources,version=15.0.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.MDD,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.MDD,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.JavaScript.LanguageService,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.JavaScript.LanguageService,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Msi,version=15.0.27005.2,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Debugger.Script,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Base.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Base.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Base,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Base,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.MSBuild.Base.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.MSBuild.Base.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.MSBuild.Base,version=15.6.27428.2015' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.MSBuild.Base,version=15.6.27428.2015' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Net.4.TargetingPack,version=4.0.30319.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Core.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Core.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine.Resources,version=15.0.27005.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine.Resources,version=15.0.27005.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Core,version=15.6.27428.2015' since the package or a parent package had a vital failure.
Superkurt
Postby Superkurt » Sun May 06, 2018 6:49 am
When I compile for Non-OS SDK 2.0.0 with ESP Boot Mode "No boot" the linker script .\ESP8266Wizard\ESPressif\Non-OS\2.0.0\ld\eagle.app.v6.ld will be used. In this linker script the irom0text.bin will be linked for address 0x10000.
  irom0_0_seg :                         org = 0x40210000, len = 0x5C000
But in the .\ESP8266Wizard\MSBuildTemplate\ESPBuilder.targets the address 0x40000 is hardcoded. At least for the Non-OS SDK 2.0.0 release this should be changed to 0x10000.
DanieliCy
Postby DanieliCy » Mon May 14, 2018 8:50 pm
Hi I triyed to install the tool and got an istallation error in the VSIX installer:
5/14/2018 3:05:25 PM - Package Microsoft.Windows.UniversalCRT.Msu.8 is not applicable. Skipping it due to the following reason(s): The current OS Version '6.1.7601.65536' is not in the supported version range '[6.2,6.3)'.
5/14/2018 3:05:25 PM - Package Microsoft.Windows.UniversalCRT.Msu.81 is not applicable. Skipping it due to the following reason(s): The current OS Version '6.1.7601.65536' is not in the supported version range '[6.3,6.4)'.
5/14/2018 3:05:25 PM - Package Microsoft.Net.4.6.1.FullRedist.Threshold is not applicable. Skipping it due to the following reason(s): The current OS Version '6.1.7601.65536' is not in the supported version range '[10.0.10240]'.
5/14/2018 3:05:25 PM - Package Microsoft.VisualStudio.Graphics.EnableTools is not applicable. Skipping it due to the following reason(s): The current OS Version '6.1.7601.65536' is not in the supported version range '10.0.10240'.
etc......
Bluescreen2001
Postby Bluescreen2001 » Tue Jun 19, 2018 4:00 pm
I tried the Wizard 1.2.9 with VS 2017 (15.5.6) using the IoT_Demo (NON_OS 2.2.0) on a NodeMCU board with MB Flash.
I can compile the demo and transfer it to my board, but it simply crashes directly after boot.
    load 0x40100000, len 30464, room 16
    tail 0
    chksum 0xc9
    load 0x3ffe8000, len 2936, room 8
    tail 0
    chksum 0x09
    load 0x3ffe8b80, len 3828, room 8
    tail 12
    chksum 0xd1
    csum 0xd1
    Fatal exception (0):
    epc1=0x40210bf4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Also the transfer is very slow.
Maybe there is something wrong with the Flash Settings. In the project's configuration ESP8266 tab I select for ESP SPI size 4096kB [512 KB + 512KB]. (512k + 512k = 1024k, not 4096k ?!). What are the right Settings here. And how can I protect the SPIFFS filesystem from a previous Arduino Project from being overwritten (I want to implement SPIFFS on plain NON_OS SDK later).
Can I use another Flash tool which is faster, e.g the esptool from the Arduino IDE.
Another small issue is, that VS displays all os_printf Statements with a read error mark, complaining about an incomplete type.
This is my first try on plain SDK programming on the ESP, so please be Patient if my questions are too dumb. ;)
Thank you
Thorsten
Fleuve
Re: ESP8266 Wizard 1.3.0 OpenSource for Visual Studio 2013, 2015 & 2017 with FlashTool, Intellisense and VIDEO Tutorial
Postby Fleuve » Fri Nov 09, 2018 12:25 am
For everyone who got problem to install under Visual Studio 2017. I've publish the 1.3.0 version, with a new VSIXInstaller update.
Sorry, for the delay... But I'm working currently on an another project and own a motel. Then I'm only check twice a year. Before and after season...
Fleuve
Users browsing this forum: No registered users and 16 guests
