ESP8266 as TCP SSL client
Postby ESP_Faye » Wed Apr 22, 2015 11:46 am
Here is a demo code of ESP8266 as TCP SSL client. It is based on ESP8266 SDK without OS.
It just like ESP8266 to be normal TCP client except change espconn_xxx to be espconn_secure_xxx
If your SSL packet is larger than 2048 bytes, please try to call espconn_secure_set_size to enlarge SSL buffer size (max: 8192)
#include "espconn.h"
#include "mem.h"
#define DNS_ENABLE
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
#define NET_DOMAIN "iot.espressif.cn"
const char* TLSHEAD = "GET / HTTP/1.1\r\nHost: %d.%d.%d.%d\r\nConnection: keep-alive\r\n\r\n";
#define packet_size   (2 * 1024)
LOCAL os_timer_t test_timer;
LOCAL struct espconn user_tcp_conn;
LOCAL struct _esp_tcp user_tcp;
ip_addr_t tcp_server_ip;
 * FunctionName : user_tcp_recv_cb
 * Description  : receive callback.
 * Returns      : none
LOCAL void ICACHE_FLASH_ATTR
user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
   //received some data from tcp connection
    os_printf("tcp recv !!! %s \r\n", pusrdata);
 * FunctionName : user_tcp_sent_cb
 * Description  : data sent callback.
 * Returns      : none
user_tcp_sent_cb(void *arg)
   //data sent successfully
    os_printf("tcp sent succeed !!! \r\n");
 * FunctionName : user_tcp_discon_cb
 * Description  : disconnect callback.
 * Returns      : none
user_tcp_discon_cb(void *arg)
   //tcp disconnect successfully
    os_printf("tcp disconnect succeed !!! \r\n");
 * FunctionName : user_esp_platform_sent
 * Description  : Processing the application data and sending it to the host
 * Parameters   : pespconn -- the espconn used to connetion with the host
 * Returns      : none
user_sent_data(struct espconn *pespconn)
   char *pbuf = (char *)os_zalloc(packet_size);
   os_sprintf(pbuf, TLSHEAD,
    pespconn->proto.tcp->remote_ip[0], pespconn->proto.tcp->remote_ip[1],
    pespconn->proto.tcp->remote_ip[2], pespconn->proto.tcp->remote_ip[3]);
   espconn_secure_sent(pespconn, pbuf, os_strlen(pbuf));
   os_free(pbuf);
 * FunctionName : user_tcp_connect_cb
 * Description  : A new incoming tcp connection has been connected.
 * Returns      : none
user_tcp_connect_cb(void *arg)
    os_printf("connect succeed !!! \r\n");
    espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
    espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
    user_sent_data(pespconn);
 * FunctionName : user_tcp_recon_cb
 * Description  : reconnect callback, error occured in TCP connection.
 * Returns      : none
user_tcp_recon_cb(void *arg, sint8 err)
   //error occured , tcp connection broke. user can try to reconnect here.
    os_printf("reconnect callback, error code %d !!! \r\n",err);
#ifdef DNS_ENABLE
 * FunctionName : user_dns_found
 * Description  : dns found callback
 * Parameters   : name -- pointer to the name that was looked up.
 *                ipaddr -- pointer to an ip_addr_t containing the IP address of
 *                the hostname, or NULL if the name could not be found (or on any
 *                other error).
 *                callback_arg -- a user-specified callback argument passed to
 *                dns_gethostbyname
 * Returns      : none
user_dns_found(const char *name, ip_addr_t *ipaddr, void *arg)
    struct espconn *pespconn = (struct espconn *)arg;
    if (ipaddr == NULL)
        os_printf("user_dns_found NULL \r\n");
        return;
   //dns got ip
    os_printf("user_dns_found %d.%d.%d.%d \r\n",
            *((uint8 *)&ipaddr->addr), *((uint8 *)&ipaddr->addr + 1),
            *((uint8 *)&ipaddr->addr + 2), *((uint8 *)&ipaddr->addr + 3));
    if (tcp_server_ip.addr == 0 && ipaddr->addr != 0)
      // dns succeed, create tcp connection
        os_timer_disarm(&test_timer);
        tcp_server_ip.addr = ipaddr->addr;
        os_memcpy(pespconn->proto.tcp->remote_ip, &ipaddr->addr, 4); // remote ip of tcp server which get by dns
        pespconn->proto.tcp->remote_port = 8443; // remote SSL port of tcp server
        pespconn->proto.tcp->local_port = espconn_port(); //local port of ESP8266
        espconn_regist_connectcb(pespconn, user_tcp_connect_cb); // register connect callback
        espconn_regist_reconcb(pespconn, user_tcp_recon_cb); // register reconnect callback as error handler
        espconn_regist_disconcb(pespconn, user_tcp_discon_cb);  // register disconnect callback here, because that SSL handshake may fail.
       espconn_secure_set_size(ESPCONN_CLIENT,5120); // set SSL buffer size, if your SSL packet larger than 2048 bytes
        espconn_secure_connect(pespconn); // tcp SSL connect
 * FunctionName : user_esp_platform_dns_check_cb
 * Description  : 1s time callback to check dns found
 * Returns      : none
user_dns_check_cb(void *arg)
    espconn_gethostbyname(pespconn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // recall DNS function
    os_timer_arm(&test_timer, 1000, 0);
#endif
 * FunctionName : user_check_ip
 * Parameters   : none
 * Returns      : none
user_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
      os_printf("got ip !!! \r\n");
      // Connect to tcp server as NET_DOMAIN
      user_tcp_conn.proto.tcp = &user_tcp;
      user_tcp_conn.type = ESPCONN_TCP;
      user_tcp_conn.state = ESPCONN_NONE;
      #ifdef DNS_ENABLE
      tcp_server_ip.addr = 0;
       espconn_gethostbyname(&user_tcp_conn, NET_DOMAIN, &tcp_server_ip, user_dns_found); // DNS function
       os_timer_setfn(&test_timer, (os_timer_func_t *)user_dns_check_cb, &user_tcp_conn);
      #else
       const char esp_server_ip[4] = {192, 185, 229, 242};
       os_memcpy(user_tcp_conn.proto.tcp->remote_ip, esp_server_ip, 4);
       user_tcp_conn.proto.tcp->remote_port = 443; // remote SSL port of tcp server
       user_tcp_conn.proto.tcp->local_port = espconn_port(); //local port of ESP8266
       espconn_regist_connectcb(&user_tcp_conn, user_tcp_connect_cb); // register connect callback
       espconn_regist_reconcb(&user_tcp_conn, user_tcp_recon_cb); // register reconnect callback as error handler
       espconn_secure_connect(&user_tcp_conn); // tcp SSL connect
      #endif
   else
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
         os_printf("connect fail !!! \r\n");
      else
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_check_ip, NULL);
 * Parameters   : none
 * Returns      : none
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
 * FunctionName : user_init
 * Parameters   : none
 * Returns      : none
void user_init(void)
   //Set station mode
   //ESP8266 connect to router
   user_set_station_config();
gustavo
Re: ESP8266 as TCP SSL client
Postby gustavo » Mon Aug 08, 2016 5:41 pm
When will this be available on the RTOS SDK?
Dashaduamp
Postby Dashaduamp » Tue Jun 20, 2017 4:10 pm
Dear Sir
I am Dushyant here
i have made Vb code for Modbus Tcp/Ip. Which works as Server/Slave as well as Client/Master.
Now my software can connect with only one server at one time
so is it possible to be connected for continusly with more then one server?
Bentjudges
Postby Bentjudges » Sun Oct 15, 2017 11:44 pm
Thanks for this post providing the SSl certificate authentication installation steps.
Sobhana123
Postby Sobhana123 » Wed Mar 13, 2019 12:59 pm
Hello, I am Sobhana working in Certvalue Company with the position of SEO Executive. We are the best ISO certification Consultants to provide ISO Certifications in major countries of the world. Such as Saudi Arabia, Kuwait, India, Oman, Jordan, Dubai, UAE.
ISO Certification in Jeddah
fillipppyatochckin
Postby fillipppyatochckin » Sun Apr 07, 2019 2:17 pm
I think you are onto something with the GUI, I checked some and there seems to come something, but nothing happened. In VB6, you have doevents, But is there anything like that in VB2017?
it seems like it stuck here;
Code:
