ESP8266 Restart loop
paweb
Postby paweb » Tue May 23, 2017 3:46 am
Hi
I've got ESP8266 12E module with adapter for prototyping. Everything works fine but now esp throws some error and reset:
Fatal exception 0(IllegalInstructionCause):
epc1=0x40201494, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
 ets Jan  8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 32Mbit(512KB+512KB)
jump to run user1 @ 1000
����n��r��n|� l lll`b� �|r�l�n� �n�ll`��r�l�l� �l`��r�l�l� l`��r�l ��� ll`rl��rl���b ��bp| bp���p���b ��n�nn� ll�� l�� l�l��� �l�rrl�n����b ll� � b ���b l �brlrl
ready
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
and over again and again :(
I try flash like this:
python ./esptool.py --port=/dev/cu.SLAB_USBtoUART write_flash -fm=dio -fs=detect 0x00000 ../AT/boot_v1.7.bin 0x001000 ../AT/user1.1024.new.2.bin 0x3fc000 ../AT/esp_init_data_default.bin 0x7e000 ../AT/blank.bin 0x3fe000 ../AT/blank.bin
i try boot v 1.2 1.6 and 1.7 and it's the same :(
What do you think ? Did i destroy flash module ?
Re: ESP8266 Restart loop
Postby ESP_Faye » Tue May 23, 2017 4:10 pm
Please try
python ./esptool.py --port=/dev/cu.SLAB_USBtoUART write_flash -fm=dio -fs=detect 0x00000 ../AT/boot_v1.7.bin 0x001000 ../AT/user1.1024.new.2.bin 0x3fc000 ../AT/esp_init_data_default.bin 0x3fe000 ../AT/blank.bin
And call "AT+RESTORE" to initialize it at first startup.
paweb
Postby paweb » Tue May 23, 2017 10:34 pm
Thx i will try this. But i bought today another ESP can i dump all of flash from brand new one and write it to the broken ?
paweb
Postby paweb » Wed May 24, 2017 1:42 am
ESP_Faye wrote:Hi,
Please try
unfortunatly still broken, even worse :(
 ets Jan  8 2013,rst cause:2, boot mode:(3,7)
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
After few of restart i can run AT+RESTORE but after this when ESP again turn "restart mode" :P
PORT OPEN 115200
Communication with MCU...
Got answer! AutoDetect firmware...
AT-based firmware detected.
AT+GMR
AT version:1.4.0.0(May  5 2017 16:10:59)
SDK version:2.1.0(116b762)
compile time:May  5 2017 16:37:48
OK
AT+CWMODE=3
OK
AT+CWJAP="paweb","QUQAAEKI"
 ets Jan  8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
ready
WIFI DISCONNECT
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
ready
wdt reset
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : DIO
I record some movie how it looks like:
https://youtu.be/kMqnGvEzae4
ESP connected to:
VCC 3V3
CH_PC - > 3V3
GND -> GND
GPIO15 -> GND
adapter had included resistor
Postby Her Mary » Wed May 24, 2017 10:12 am
In fact, "ready" means that the AT core started up correctly and ready to receive any AT commands.
Maybe you can try: python ./esptool.py --port=/dev/cu.SLAB_USBtoUART write_flash -fm=qio -fs=detect 0x00000 ../AT/boot_v1.7.bin 0x001000 ../AT/user1.1024.new.2.bin 0x7e000 ../AT/blank.bin 0x3fb000 ../AT/blank.bin 0x3fc000 ../AT/esp_init_data_default.bin 0x3fe000 ../AT/blank.bin
Users browsing this forum: Google [Bot] and 4 guests
