AT command firmware source code is not available.
ronakshah
Postby ronakshah » Fri May 26, 2017 6:07 pm
I am very new to ESP8266 - I want to know that ESP8266 AT command firmware source code is not available to in the SDK form
Re: AT command firmware source code is not available.
Postby ESP_Faye » Sat May 27, 2017 9:28 am
Sorry that ESP8266 AT command is not open source.
But ESP32 AT is open source.
blandodo
Postby blandodo » Thu Aug 24, 2017 5:54 pm
Hi~
where can I find the source code of ESP32 AT ?
I can only find libat_core.a at https://github.com/espressif/esp32-at
I appreciat that customers can overwrite some comamnd's action by call function 'at_cmd_array_regist'
c1728p9
Postby c1728p9 » Thu Apr 19, 2018 8:57 am
Has the ESP8266 AT command firmware source code been publicly released? I see this repository on github which seems like it:
https://github.com/espressif/ESP8266_AT
andreysnug
Postby andreysnug » Mon Jun 18, 2018 7:12 am
If your programmer has a 9-5 job with you, then you should own the source. I know that every 9-5 Ive worked, they have the rights to my code.
