Hostname (standard PC-192-168-xxx-xxx)
Re: Hostname (standard PC-192-168-xxx-xxx)
Postby ESP_Faye » Tue Aug 18, 2015 9:58 am
Sorry that we can not duplicate your problem.
Here is our test code:
void ICACHE_FLASH_ATTR
user_esp_platform_check_ip(void)
    struct ip_info ipconfig;
   //disarm timer first
    os_timer_disarm(&test_timer);
   //get ip info of ESP8266 station
    if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0) {
      os_printf("got ip !!! \r\n");
     wifi_station_set_hostname("esp8266");
     espconn_nbns_init();
    } else {
        if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
                wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
                wifi_station_get_connect_status() == STATION_CONNECT_FAIL)) {
         os_printf("connect fail !!! \r\n");
        } else {
           //re-arm timer to check ip
            os_timer_setfn(&test_timer, (os_timer_func_t *)user_esp_platform_check_ip, NULL);
            os_timer_arm(&test_timer, 100, 0);
user_set_station_config(void)
   // Wifi configuration
   char ssid[32] = SSID;
   char password[64] = PASSWORD;
   //need not mac address
   stationConf.bssid_set = 0;
   //Set ap settings
   //set a timer to check whether got ip from router succeed or not.
void user_init(void)
   //Set  station mode
   // ESP8266 connect to router.
   user_set_station_config();
- Do I need to call espconn_nbns_init every time ESP8266 got an IP?
-> Yes.
- Do I need to call espconn_nbns_init every time I change the host name with wifi_station_set_hostname?
-> No. It is enough calling it only once after got an IP.
blubb
Postby blubb » Tue Aug 18, 2015 7:19 pm
No, does not work.
In the mean time I found a tool that can list NETBIOS nameservers on the local network:
http://www.unixwiz.net/tools/nbtscan.html
All my Windows machines and the Linux machines running Samba show up on the list. ESP8266 does not.
Postby ESP_Faye » Mon Aug 24, 2015 5:29 pm
With the code I provided above, it can ping "esp8266" successfully.
If your problem is still unsolved, please provide your test code and test steps, we will have a try.
blubb
Postby blubb » Mon Aug 24, 2015 5:51 pm
"esp8266" might be resolved by DNS, not NBNS on your system. Remove espconn_nbns_init() then try again. If pinging still works, your system uses DNS.
I found out that my Windows 7 machine does this, too. My Windows 10 machine tries NBNS only and cannot ping the module by host name (I have no idea why).
Try
nbtstat -a esp8266
It's a tool that comes with Windows: https://technet.microsoft.com/en-us/library/cc755486(v=ws.10).aspx
If NBNS works, there should be some output (compare it with, for example, a Linux system running Samba).
webself
Postby webself » Fri Sep 25, 2015 2:50 pm
Why SDK 1.4 still does not include this feature?
I check espconn.h for "espconn_nbns_init" and nothing was found...
blubb
Postby blubb » Fri Sep 25, 2015 7:09 pm
Did the feature work for you (in SDK 1.3.0)? Were your Windows machines able to resolve the host names?
webself
Postby webself » Fri Sep 25, 2015 7:13 pm
I have not tried.
