How to use the wifi light sleep?
BearPeak
Postby BearPeak » Thu Jul 27, 2017 8:46 am
My project use idf is ESP8266_RTOS_SDK,but i don't know how to use the wifi light sleep .
It will get in light sleep auto when run the idle task or not ?
If the chip can get in sight sleep ,what is the current of the esp8266?
Re: How to use the wifi light sleep?
Postby pratik » Mon Jul 31, 2017 2:17 pm
Try this document:
http://www.espressif.com/sites/default/ ... ons_en.pdf
It will clarify on which sleep mode is best for your project.
gladysjenkins2019
Location: https://www.achieveessays.com/essay-writer.html
Postby gladysjenkins2019 » Mon Jan 14, 2019 4:45 pm
So do I need to add code lines in my setup to make sure the ESP is in client mode and light sleeping is enabled?
StanJ
Postby StanJ » Sat Feb 08, 2020 10:28 pm
gladysjenkins2019 wrote:So do I need to add code lines in my setup to make sure the ESP is in client mode and light sleeping is enabled?
Gladys, yes, Automatic Light Sleep is not enabled by default, only Automatic Modem Sleep, so you need to add the wifi_set_sleep_type(LIGHT_SLEEP_T) SDK call to enable Light Sleep. I see power drop to ~ 4mA during Light Sleep between beacons. It will go lower than 4mA, but you have to disable all timers (which loses the WiFi connection).
Depending on the DTIM listen interval Light Sleep runs at, you may miss packets in Station mode. If you can't afford to lose data, then you will want to use the default Modem Sleep instead (~15mA between TIM beacons, but no lost data). You don't have to do anything in your code to get Modem Sleep, it's running soon after you establish a connection. If you have frequent 'idle' calls in your program you'll see the power drop. For the Arduino IDE, 'idle' = delay(). Without 'idle', the modem never sleeps and substrate current is ~70mA.
AndreasSmith
Postby AndreasSmith » Sat Mar 28, 2020 8:53 pm
ResumeWritingServicesUS
This PDF will clear you all questions regarding the Wifi Light sleep...
https://www.espressif.com/sites/default ... ons_en.pdf
