LwIP and mDNS
mriksman
LwIP and mDNS
Postby mriksman » Tue Jun 30, 2020 5:26 pm
Hi All,
When I call this;
struct addrinfo hints, *res;
int status;
memset(&hints, 0, sizeof(hints));
hints.ai_family = AF_INET;
hints.ai_socktype = SOCK_STREAM;
char *host = "esp_942daf.local";
char *port = "5556";
status = getaddrinfo("esp_942daf.local", "80", &hints, &res)
I get
EAI_FAIL
Looking at WireShark, I am seeing the requests;
192.168.1.187   224.0.0.251   MDNS   Standard query 0x3090 A esp_942daf.local, "QM" question
But no response.
I then call immediately after the following;
struct ip4_addr addr;
addr.addr = 0;
mdns_query_a("esp_99a744", 2000,  &addr);
And it correctly resolves the address. Noteably, this time the request is of type QU;
192.168.1.187   224.0.0.251   MDNS   Standard query 0x0000 A esp_99a744.local, "QU" question
I also tried another mDNS hostname; a HP printer with name
HPC8D9D240DB2B.local
, and
getaddrinfo
resolves it correctly.
So, why isn't the ESP module responding to a QM mDNS query? Why is LwIP and mDNS using different query types? What else can I try?
Re: LwIP and mDNS
Postby Her Mary » Sun Jul 19, 2020 1:17 pm
mriksman
Re: LwIP and mDNS
Postby mriksman » Sun Jul 19, 2020 1:33 pm
I’ve raised an Issue on the ESP-IDF GitHub. They’ve confirmed the issue.
Users browsing this forum: Baidu [Spider] and 6 guests
