tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
SDK:3.0.0-dev(c0f7b44)/Core:win-2.5.0-dev/lwIP:2.0.3(STABLE-2_0_3_RELEASE/glue:arduino-2.4.1-13-g163bb82)/BearSSL:94e9704
WPA2 ENTERPRISE VERSION: [v2.0] enable
scandone
Waiting for connection and IP Address from DHCP
wifi evt: 8
wifi evt: 2
.scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
EAP-MSCHAPV2: RX identifier 3 mschapv2_id 3
EAP-MSCHAPV2: Generate Challenge Response
EAP-MSCHAPV2: RX identifier 4 mschapv2_id 3
there is no poison after the block. Expected poison address: 0x41491208, actual data: 0x0e 0x00 0x00 0x00
block start: 3fff10bc
Panic C:\Program Files (x86)\Arduino\hardware\esp8266com\esp8266\cores\esp8266\umm_malloc\umm_malloc.c:861 check_poison_block
ctx: sys
sp: 3fffec50 end: 3fffffb0 offset: 01b0
>>>stack>>>
