system_phy_freq_trace_enable()
st0ff3r
Postby st0ff3r » Fri Apr 06, 2018 4:20 am
Hi, can any of you enlighten me of the meaning of sdk function system_phy_freq_trace_enable()?
Re: system_phy_freq_trace_enable()
Postby Her Majesty » Sat Apr 07, 2018 5:29 pm
Maybe you can refer to the API Reference Guide.
It says
For the high-temperature scenario, user can call system_phy_freq_trace_enable(1) in user_rf_pre_init to enable frequency offset trace function.
st0ff3r
Postby st0ff3r » Sat Apr 07, 2018 7:12 pm
Why is it not turned on by default? Could it in any way be related to this problem: https://tech.scargill.net/esp8266-and-l ... nection-2/
Does the option make the chip try to stay on the right frequency or does it just log deviation?
blubb
Postby blubb » Sun Apr 08, 2018 5:52 pm
Documentation is very poor on this api.
If it is improved, I'd also like to know what the numbers mean. If enabled, new stuff like this is logged:
f r0, scandone
sta scan trace -19
reconnect
f r-19, scandone
