Why is RTC timer lost during deep sleep?
tve
Postby tve » Sat Oct 03, 2015 2:44 pm
Is it a design feature that the RTC timer is lost during deep sleep? I observe the following (using SDK 1.3):
    The chip is awakened from deep sleep after a timer expiration using a gpio16->ext_rst connection
    The RTC memory (system_rtc_mem_read/write) is preserved during deep sleep
    The RTC clock must be running during deep sleep since it awakens the chip
    When the chip awaken, the RTC clock (system_get_rtc_time) is reset to 0
Why?
tve
Re: Why is RTC timer lost during deep sleep?
Postby tve » Sat Oct 03, 2015 3:01 pm
By the way, is it expected that after a deep sleep system_get_rst_info->reason == REASON_EXT_SYS_RST and not REASON_DEEP_SLEEP_AWAKE ?
dkinzer
Postby dkinzer » Sat Oct 03, 2015 11:16 pm
tve wrote:is it expected that after a deep sleep system_get_rst_info->reason == REASON_EXT_SYS_RST and not REASON_DEEP_SLEEP_AWAKE ?
That is a bug in v1.3.0 (and probably earlier) of the SDK. It was fixed in a special build of v1.3.0 but I haven't checked to see if the correction made it into v1.4.0.
Don Kinzer
Beaverton, OR, USA
tve
Postby tve » Sun Oct 04, 2015 2:12 am
Thanks for the note about the reset reason, it is fixed in 1.4!
The fact that the RTC clock is reset is still a puzzle.
torntrousers
Postby torntrousers » Thu Oct 08, 2015 2:35 pm
I'm interested in this question too -
It would be really useful if there was a way to prevent that happening.
Postby ESP_Faye » Tue Oct 13, 2015 9:47 am
Sorry for the inconvenience.
ESP8266 designed like this, wake up from deep-sleep, the RTC timer will be reset, but the data stored in RTC memory will not.
You could call system_get_rtc_time before deep-sleep and write the value into RTC memory by system_rtc_mem_write.
eriksl
Postby eriksl » Thu Oct 15, 2015 3:50 pm
Interesting though, because the RTC is supposed to keep running in deep sleep, because it needs to be able to wakeup the rest of the chip...
Dmytro
Postby Dmytro » Thu Dec 03, 2015 1:31 am
Reset RTC to 0 is real problem for me, I use deep-sleep, and during sleep time interrupt from external sensor may occur. External sensor connected to RESET line of ESP8266 and must wake up module, but after wake-up I can't calculate time was sleeping (and time left). Can you give some mechanism for direct RTC control? I didn't found detailed description of RTC module (registers, control bits and so on).
eriksl
Postby eriksl » Sat Dec 05, 2015 7:32 pm
Add external RTC, their very cheap (using I2C for example).
SpenZerX
Contact:
Postby SpenZerX » Mon Dec 14, 2015 4:56 pm
Will RTC timer keep running in deep sleep when connecting PIN VDD_RTC?
