ESP8266 RAM Size
Re: ESP8266 RAM Size
Postby Espressif_Kelly » Fri Jan 09, 2015 7:07 pm
Dear Sir,
Based on the present SDK, the available space that customers can use are as below.
RAM size <45kB (In station Mode, when connected to AP, the available space of heap+data is about 40+KB)
No programm rom in chip, user codes are strored in spi flash. Take 4Mbit spi flash as example,the current available program area is <64KB.
The maximum size of flash that ESP8266 support can be up to 128Mbit.
Postby scargill » Fri Feb 12, 2016 9:34 pm
It would appear that as of SDK 1.5.2, Espressif are using more .TEXT Ram - my code which compiles perfectly under 1.5.1 and previous will no longer compile complaining that it is out of .TEXT space.
What can be done to reduce this - I already have my functions using the DIRECTIVE to keep functions in FLASH.... is it possible to eliminate some materials in the SDK from compilation? I don't use the AT commands for example..... or the WIFI NOW stuff - if .TEXT Ram cannot be recovered I'm forever doomed to use SDK 1.51
Postby scargill » Fri Mar 25, 2016 2:54 am
Espressif - any chance of a reply to this one - I cannot use the latest SDK as my .TEXT memory is at 7ace on the previous SDK and runs out with the new one - anything I can strip out or change in the SDK? I've already put all my routines in FLASH
Postby ESP_Faye » Fri Mar 25, 2016 9:50 am
Please provide your ".dump" file which is generated by compilation. We will help optimize it.
If you can not compile it successfully, please change the length of text from 0x8000 to 0x9000 in ld file temporarily, just in order to pass the compilation.
Users browsing this forum: No registered users and 188 guests
