error: pll_cal exceeds 2ms!!!
mash
Postby mash » Fri Apr 29, 2016 3:44 pm
I'm seeing this
lines in UART when I power the module.
What does this error mean?
I haven't seen anyone else writing about this error.
I'm using ESP-WROOM-02 and SDK VERSION:1.5.3(aec24ac9)
This seems to be unrelated to software, because it happens when my user_init is like:
void user_init(void) {
Re: error: pll_cal exceeds 2ms!!!
Postby ESP_Faye » Tue May 03, 2016 1:40 pm
This log means that operating RF during sleep mode, maybe you can disable the sleep mode and test it again.
wifi_set_sleep_type(NONE_SLEEP_T);
mkeyno
Postby mkeyno » Fri Sep 30, 2016 8:55 pm
I have same problem
just after soldering the fresh ESP-12F on the board and upload the helloworld example of esp8266/Arduino , its throw
in every couple of second without any crash and exception, instead no connection lunched whereas serial print shows its work and gain the ip address , I've checked couple of lib example as well and also put the wifi_set_sleep_type(NONE_SLEEP_T); inside setup but no success
is it possible the module had broken ?
Users browsing this forum: No registered users and 286 guests
