GPIO REGISTER AND PIN LIST !!
Postby costaud » Wed Nov 05, 2014 1:38 am
ESP8266 is really powerfull!!
NOTE:
1. Keep an eye on the strapping page, UOTXD,MTDO,GPIO0,GPIO2 might affect the boot-mode.
2. The input and output side both connect to the pad.When the output is disabled , it is set to be an input pin.
3. Each gpio has a same first-order sigma-delta pwm source, which can generate a hardware pwm signal.
Next , spi and uart register spec will be released soon.
NOTE:
- Attachments
- ESP8266_Pin_List_141105.xlsx
- (64.6 KiB) Downloaded 2381 times
- ESP8266_GPIO_Register_141105.xls
- (31.5 KiB) Downloaded 2644 times
Re: GPIO REGISTER AND PIN LIST !!
Postby rudi » Tue Nov 11, 2014 7:07 pm
hi costaud, thank you.
is there a adress list for read values example
- MAC Adress AP ( Flash tool read it 'barcode' )
- MAC Adress Station ( Flash Tool read it 'barcode' )
- CHIP ID ( will be fine like MAC Adress in Flash Tool )
- 'companion ID' ( .. )
will help to sort out in produktion
see forward to your post
best wishes
rudi
best wishes
rudi
問候飛出去的朋友遍全球魯迪
Postby rudi » Tue Nov 11, 2014 10:18 pm
like this
Base Adress MAC Adress:
0x3ff00050
0x3ff00054
0x3ff00058
0x3ff0005c
CHIP ID :
examples are in esptool.py too..
viewtopic.php?f=7&t=25
short code
long code
0x3ff00050
0x3ff00054
0x3ff00058
0x3ff0005c
CHIP ID :
reg1 = self.read_reg(0x3ff00050)
reg2 = self.read_reg(0x3ff00054)
reg3 = self.read_reg(0x3ff00058)
reg4 = self.read_reg(0x3ff0005c)
short code
"""read mac addr"""
def get_mac(self):
retry_times = 3
try:
except:
print "read reg error"
return False
chip_flg = ( reg3>>15 )&0x1
if chip_flg == 0:
print 'warning : ESP8089 CHIP DETECTED, STOP'
return False
else:
print 'chip_flg',chip_flg
m0 = ((reg2>>16)&0xff)
m1 = ((reg2>>8)&0xff)
m2 = ((reg2 & 0xff ))
m3 = ((reg1>>24)&0xff)
self.MAC2 = m0
self.MAC3 = m1
self.MAC4 = m2
self.MAC5 = m3
if m0 ==0:
print "r1: %02x; r2:%02x ; r3: %02x"%(m1,m2,m3)
mac= "1A-FE-34-%02x-%02x-%02x"%(m1,m2,m3)
mac2 = "1AFE34%02x%02x%02x"%(m1,m2,m3)
mac = mac.upper()
mac2 = mac2.upper()
mac_ap = ("1A-FE-34-%02x-%02x-%02x"%(m1,m2,m3)).upper()
mac_sta = ("18-FE-34-%02x-%02x-%02x"%(m1,m2,m3)).upper()
elif m0 == 1:
mac= "AC-D0-74-%02x-%02x-%02x"%(m1,m2,m3)
mac2 = "ACD074%02x%02x%02x"%(m1,m2,m3)
mac = mac.upper()
mac2 = mac2.upper()
mac_ap = ("AC-D0-74-%02x-%02x-%02x"%(m1,m2,m3)).upper()
mac_sta = ("AC-D0-74-%02x-%02x-%02x"%(m1,m2,m3)).upper()
else:
print "mac read error ..."
return False
long code
# coding=gbk
#!/usr/bin/env python
# ESP8266 ROM Bootloader Utility
# https://github.com/themadinventor/esptool
# Copyright (C) 2014 Fredrik Ahlberg
# This program is free software; you can redistribute it and/or modify it under
# the terms of the GNU General Public License as published by the Free Software
# Foundation; either version 2 of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
# FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
# You should have received a copy of the GNU General Public License along with
# this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
# Street, Fifth Floor, Boston, MA 02110-1301 USA.
import sys
reload(sys)
sys.setdefaultencoding('gbk')
code_type = sys.getfilesystemencoding()
import sys
import struct
import serial
import math
import time
import shutil
import os
#import argparse
class ESPROM:
# These are the currently known commands supported by the ROM
ESP_FLASH_BEGIN = 0x02
ESP_FLASH_DATA = 0x03
ESP_FLASH_END = 0x04
ESP_MEM_BEGIN = 0x05
ESP_MEM_END = 0x06
ESP_MEM_DATA = 0x07
ESP_SYNC = 0x08
ESP_WRITE_REG = 0x09
ESP_READ_REG = 0x0a
# Maximum block sized for RAM and Flash writes, respectively.
ESP_RAM_BLOCK = 0x1800
ESP_FLASH_BLOCK = 0x400
# Default baudrate used by the ROM. Don't know if it is possible to change.
ESP_ROM_BAUD = 115200
# First byte of the application image
ESP_IMAGE_MAGIC = 0xe9
# Initial state for the checksum routine
ESP_CHECKSUM_MAGIC = 0xef
ESP_MAC = ""
#download state
ESP_DL_OK = 0x0
ESP_DL_IDLE = 0x1
ESP_DL_CONNECT_ERROR = 0x2
ESP_DL_SYNC = 0x3
ESP_DL_SYNC_ERROR = 0x4
ESP_DL_ERASE = 0x5
ESP_DL_ERASE_ERROR = 0x6
ESP_DL_DOWNLOADING = 0x7
ESP_DL_DOWNLOAD_ERROR = 0x8
ESP_DL_FAIL = 0x9
ESP_DL_FINISH = 0xA
ESP_DL_STOP = 0xB
def __init__(self, frame, port = 6, baudrate = 115200):
self._COM = port
self.ESP_ROM_BAUD = baudrate
self.isOpen = False
self.stopFlg = False
self.state = self.ESP_DL_IDLE
self.process_num = 0
self.MAC2 = 0
self.MAC3 = 0
self.MAC4 = 0
self.MAC5 = 0
self.frame = frame
print "_COM: ",self._COM
print "ESP_ROM_BAUD : ",self.ESP_ROM_BAUD
"""reset some status used"""
def reset(self):
self.isOpen = False
"""close com port"""
def disconnect(self):
if self.isOpen:
self._port.close()
print "com closed"
self.isOpen = False
else:
print "already closed"
"""open RS232 port"""
def com_connect(self,com_port=6,baudrate=115200):
if self.isOpen:
print 'com open'
self._port.close()
print "com port closed"
self._COM = com_port
try:
self._port = serial.Serial(self._COM-1,self.ESP_ROM_BAUD)
print "serial port opened"
self.isOpen = True
self.stopFlg=False
self.state = self.ESP_DL_SYNC
return True
except:
print "serial port open error"
self.state = self.ESP_DL_CONNECT_ERROR
return False
"""synchronize baudrate"""
def device_sync(self):
if self.isOpen==False:
print "error : com not open"
else:
try:
self.connect()
print "chip sync ok!"
return True
except:
print "chip sync error."
self.state = self.ESP_DL_SYNC_ERROR
return False
def flash_download(self,filename = '', address = 0,reboot=False):
self.state = self.ESP_DL_DOWNLOADING
image = file(filename, 'rb').read()
print 'Erasing flash...'
try:
self.flash_begin(len(image), address)
except:
print "erase flash error"
self.state = self.ESP_DL_ERASE_ERROR
return False
seq = 0
blocks = math.floor(len(image)/self.ESP_FLASH_BLOCK +1 )
try:
while len(image) > 0 and not self.stopFlg:
print '\rWriting at 0x%08x... (%d %%)' % (address + seq*self.ESP_FLASH_BLOCK, 100*self.process_num/self.total_len),#100*seq/blocks),
self.process_num +=1
sys.stdout.flush()
self.flash_block(image[0:self.ESP_FLASH_BLOCK], seq)
image = image[self.ESP_FLASH_BLOCK:]
seq += 1
if self.stopFlg:
print 'stop...'
else:
print '\nLeaving...'
self.state = self.ESP_DL_FINISH
return True
except:
print "error when download firmware"
self.state = self.ESP_DL_DOWNLOAD_ERROR
return False
"""a serial steps of downloading"""
def flash_download_thread(self,com,baudrate,_dl_list):
self.ESP_MAC = ""
self._COM=com
self.ESP_ROM_BAUD=baudrate
self.stopFlg=False
self.total_len = 0
self.dl_list = []+_dl_list
ret = True
if self.isOpen==True:
self.disconnect()
ret = self.com_connect(self._COM,self.ESP_ROM_BAUD)
if ret:
ret = self.device_sync()
if ret:
ret = self.get_mac()
if ret:
try:
if self.frame.panel_idBindPanel.get_bind_enable():
if self.MAC2==0:
ltmp = self.id_bind(0x18,0xfe,0x34,self.MAC3,self.MAC4,self.MAC5,self.frame.panel_idBindPanel.get_bind_addr())
elif self.MAC2==1:
ltmp = self.id_bind(0xAC,0xD0,0x74,self.MAC3,self.MAC4,self.MAC5,self.frame.panel_idBindPanel.get_bind_addr())
else:
print "SELF.MAC2 JUDGE ERROR ..."
ret = False
self.dl_list.append(ltmp)
pass
except:
print "id bind generate error"
ret = False
pass
if ret:
image_list = []
for idx in range(len(self.dl_list)):
filename,offset = self.dl_list[idx]
print 'filename: ',filename
print 'offset : ',offset
self.total_len += blocks
#print "total len !!!=============",self.total_len
image_list.append(image)
for filename,offset in self.dl_list:
ret = self.flash_download(filename,offset,False)
if not ret or self.stopFlg:
break
if self.isOpen:
self.disconnect()
if self.stopFlg:
self.state = self.ESP_DL_STOP
"""write mac addr into a given addr of flash"""
def id_bind(self,mac0,mac1,mac2,mac3,mac4,mac5,addr):
rep_path = os.path.join( os.path.abspath('./'),'bin_tmp')
if not os.path.isdir(rep_path):
os.mkdir(rep_path)
f = file('./bin_tmp/id_bind.bin','wb')
print "test addr : ",addr
offset = addr%0x1000
id_data = '\xff'*offset
id_data +="%c%c%c%c%c%c"%(mac0,mac1,mac2,mac3,mac4,mac5)
#if (0x10-offset-6)>0:
id_data += '\xff'*(4-(offset+6)%4)
print('id data : ',id_data)
f.write(id_data)
f.close()
del(f)
time.sleep(0.1)
return [rep_path+'/id_bind.bin',addr-addr%0x1000]
"""stop downloading"""
def stop_download(self):
self.stopFlg=True
"""read mac addr"""
def get_mac(self):
retry_times = 3
try:
except:
return False
if chip_flg == 0:
return False
else:
self.MAC2 = m0
self.MAC3 = m1
self.MAC4 = m2
self.MAC5 = m3
if m0 ==0:
mac = mac.upper()
mac2 = mac2.upper()
elif m0 == 1:
mac = mac.upper()
mac2 = mac2.upper()
else:
return False
#self.mp.textCtrl_BinPath3.SetValue("AP:"+mac_ap+'\n'+"STA:"+mac_sta)
#self.mp.textCtrl_BinPath3.SetValue(mac_sta)
f_mac = open("./MAC_ADDR/MAC_TABLE.CSV",'a')
f_mac.write(mac_ap+','+mac_ap.replace("-","")+","+mac_sta+","+mac_sta.replace("-","")+'\n')
f_mac.close()
print 'MAC AP : %s'%mac_ap
print 'MAC STA: %s'%mac_sta
######self.gen_bar(mac)
self.ESP_MAC_AP = mac_ap
self.ESP_MAC_STA = mac_sta
#self.mp.MAC=mac
return True
""" Read bytes from the serial port while performing SLIP unescaping """
def read(self, length = 1):
b = ''
while len(b) < length:
c = self._port.read(1)
if c == '\xdb':
if c == '\xdc':
b = b + '\xc0'
elif c == '\xdd':
b = b + '\xdb'
else:
raise Exception('Invalid SLIP escape')
else:
b = b + c
return b
""" Write bytes to the serial port while performing SLIP escaping """
def write(self, packet):
buf = '\xc0'
for b in packet:
if b == '\xc0':
buf += '\xdb\xdc'
elif b == '\xdb':
buf += '\xdb\xdd'
else:
buf += b
buf += '\xc0'
self._port.write(buf)
""" Calculate checksum of a blob, as it is defined by the ROM """
@staticmethod
def checksum(data, state = ESP_CHECKSUM_MAGIC):
for b in data:
state ^= ord(b)
return state
""" Send a request and read the response """
def command(self, op = None, data = None, chk = 0):
if op:
# Construct and send request
pkt = struct.pack('<BBHI', 0x00, op, len(data), chk) + data
self.write(pkt)
# Read header of response and parse
if self._port.read(1) != '\xc0':
raise Exception('Invalid head of packet')
hdr = self.read(8)
(resp, op_ret, len_ret, val) = struct.unpack('<BBHI', hdr)
if resp != 0x01 or (op and op_ret != op):
raise Exception('Invalid response')
# The variable-length body
body = self.read(len_ret)
# Terminating byte
if self._port.read(1) != chr(0xc0):
raise Exception('Invalid end of packet')
return val, body
""" Perform a connection test """
def sync(self):
self.command(ESPROM.ESP_SYNC, '\x07\x07\x12\x20'+32*'\x55')
for i in xrange(7):
self.command()
""" Try connecting repeatedly until successful, or giving up """
def connect(self):
print 'Connecting...'
self._port.timeout = 0.2
for i in xrange(50):
if self.stopFlg:
print 'stop...'
break
else:
try:
self._port.flushInput()
self._port.flushOutput()
self.sync()
self._port.timeout = 1
return 0
except:
time.sleep(0.05)
raise Exception('Failed to connect')
""" Read memory address in target """
def read_reg(self, addr):
res = self.command(ESPROM.ESP_READ_REG, struct.pack('<I', addr))
if res[1] != "\0\0":
raise Exception('Failed to read target memory')
return res[0]
""" Write to memory address in target """
def write_reg(self, addr, value, mask, delay_us = 0):
if self.command(ESPROM.ESP_WRITE_REG,
struct.pack('<IIII', addr, value, mask, delay_us))[1] != "\0\0":
raise Exception('Failed to write target memory')
""" Start downloading an application image to RAM """
def mem_begin(self, size, blocks, blocksize, offset):
if self.command(ESPROM.ESP_MEM_BEGIN,
struct.pack('<IIII', size, blocks, blocksize, offset))[1] != "\0\0":
raise Exception('Failed to enter RAM download mode')
""" Send a block of an image to RAM """
def mem_block(self, data, seq):
if self.command(ESPROM.ESP_MEM_DATA,
struct.pack('<IIII', len(data), seq, 0, 0)+data, ESPROM.checksum(data))[1] != "\0\0":
raise Exception('Failed to write to target RAM')
""" Leave download mode and run the application """
def mem_finish(self, entrypoint = 0):
if self.command(ESPROM.ESP_MEM_END,
struct.pack('<II', int(entrypoint == 0), entrypoint))[1] != "\0\0":
raise Exception('Failed to leave RAM download mode')
""" Start downloading to Flash (performs an erase) """
def flash_begin(self, size, offset):
old_tmo = self._port.timeout
self._port.timeout = 10
if self.command(ESPROM.ESP_FLASH_BEGIN,
struct.pack('<IIII', size, 0x200, 0x400, offset))[1] != "\0\0":
raise Exception('Failed to enter Flash download mode')
self._port.timeout = old_tmo
""" Write block to flash """
def flash_block(self, data, seq):
if self.command(ESPROM.ESP_FLASH_DATA,
raise Exception('Failed to write to target Flash')
""" Leave flash mode and run/reboot """
def flash_finish(self, reboot = False):
if self.command(ESPROM.ESP_FLASH_END,
struct.pack('<I', int(not reboot)))[1] != "\0\0":
raise Exception('Failed to leave Flash mode')
class ESPFirmwareImage:
def __init__(self, filename = None):
self.segments = []
self.entrypoint = 0
if filename is not None:
f = file(filename, 'rb')
(magic, segments, _, _, self.entrypoint) = struct.unpack('<BBBBI', f.read(8))
# some sanity check
if magic != ESPROM.ESP_IMAGE_MAGIC or segments > 16:
raise Exception('Invalid firmware image')
for i in xrange(segments):
(offset, size) = struct.unpack('<II', f.read(8))
if offset > 0x40200000 or offset < 0x3ffe0000 or size > 65536:
raise Exception('Suspicious segment %x,%d' % (offset, size))
self.segments.append((offset, size, f.read(size)))
# Skip the padding. The checksum is stored in the last byte so that the
# file is a multiple of 16 bytes.
align = 15-(f.tell() % 16)
f.seek(align, 1)
self.checksum = ord(f.read(1))
def add_segment(self, addr, data):
self.segments.append((addr, len(data), data))
def save(self, filename):
f = file(filename, 'wb')
f.write(struct.pack('<BBBBI', ESPROM.ESP_IMAGE_MAGIC, len(self.segments), 0, 0, self.entrypoint))
checksum = ESPROM.ESP_CHECKSUM_MAGIC
for (offset, size, data) in self.segments:
f.write(struct.pack('<II', offset, size))
f.write(data)
checksum = ESPROM.checksum(data, checksum)
f.seek(align, 1)
f.write(struct.pack('B', checksum))
def arg_auto_int(x):
return int(x, 0)
if __name__ == '__main__':
pass
#parser = argparse.ArgumentParser(description = 'ESP8266 ROM Bootloader Utility', prog = 'esptool')
#parser.add_argument(
#'--port', '-p',
#help = 'Serial port device',
#default = '/dev/ttyUSB0')
#subparsers = parser.add_subparsers(
#dest = 'operation',
#help = 'Run esptool {command} -h for additional help')
#parser_load_ram = subparsers.add_parser(
#'load_ram',
#help = 'Download an image to RAM and execute')
#parser_load_ram.add_argument('filename', help = 'Firmware image')
#parser_dump_mem = subparsers.add_parser(
#'dump_mem',
#help = 'Dump arbitrary memory to disk')
#parser_dump_mem.add_argument('address', help = 'Base address', type = arg_auto_int)
#parser_dump_mem.add_argument('size', help = 'Size of region to dump', type = arg_auto_int)
#parser_dump_mem.add_argument('filename', help = 'Name of binary dump')
#parser_read_mem = subparsers.add_parser(
#'read_mem',
#help = 'Read arbitrary memory location')
#parser_read_mem.add_argument('address', help = 'Address to read', type = arg_auto_int)
#parser_write_mem = subparsers.add_parser(
#'write_mem',
#help = 'Read-modify-write to arbitrary memory location')
#parser_write_mem.add_argument('address', help = 'Address to write', type = arg_auto_int)
#parser_write_mem.add_argument('value', help = 'Value', type = arg_auto_int)
#parser_write_mem.add_argument('mask', help = 'Mask of bits to write', type = arg_auto_int)
#parser_write_flash = subparsers.add_parser(
#'write_flash',
#help = 'Write a binary blob to flash')
#parser_write_flash.add_argument('address', help = 'Base address, 4KiB-aligned', type = arg_auto_int)
#parser_write_flash.add_argument('filename', help = 'Binary file to write')
#parser_image_info = subparsers.add_parser(
#'image_info',
#help = 'Dump headers from an application image')
#parser_image_info.add_argument('filename', help = 'Image file to parse')
#parser_make_image = subparsers.add_parser(
#'make_image',
#help = 'Create an application image from binary files')
#parser_make_image.add_argument('output', help = 'Output image file')
#parser_make_image.add_argument('--segfile', '-f', action = 'append', help = 'Segment input file')
#parser_make_image.add_argument('--segaddr', '-a', action = 'append', help = 'Segment base address', type = arg_auto_int)
#parser_make_image.add_argument('--entrypoint', '-e', help = 'Address of entry point', type = arg_auto_int, default = 0)
#args = parser.parse_args()
## Create the ESPROM connection object, if needed
#esp = None
#if args.operation not in ('image_info','make_image'):
#esp = ESPROM(args.port)
#esp.connect()
## Do the actual work. Should probably be split into separate functions.
#if args.operation == 'load_ram':
#image = ESPFirmwareImage(args.filename)
#print 'RAM boot...'
#for (offset, size, data) in image.segments:
#print 'Downloading %d bytes at %08x...' % (size, offset),
#sys.stdout.flush()
#esp.mem_begin(size, math.ceil(size / float(esp.ESP_RAM_BLOCK)), esp.ESP_RAM_BLOCK, offset)
#seq = 0
#while len(data) > 0:
#esp.mem_block(data[0:esp.ESP_RAM_BLOCK], seq)
#data = data[esp.ESP_RAM_BLOCK:]
#seq += 1
#print 'done!'
#print 'All segments done, executing at %08x' % image.entrypoint
#esp.mem_finish(image.entrypoint)
#elif args.operation == 'read_mem':
#print '0x%08x = 0x%08x' % (args.address, esp.read_reg(args.address))
#elif args.operation == 'write_mem':
#esp.write_reg(args.address, args.value, args.mask, 0)
#print 'Wrote %08x, mask %08x to %08x' % (args.value, args.mask, args.address)
#elif args.operation == 'dump_mem':
#f = file(args.filename, 'wb')
#for i in xrange(args.size/4):
#d = esp.read_reg(args.address+(i*4))
#f.write(struct.pack('<I', d))
#if f.tell() % 1024 == 0:
#print '\r%d bytes read... (%d %%)' % (f.tell(), f.tell()*100/args.size),
#sys.stdout.flush()
#print 'Done!'
#elif args.operation == 'write_flash':
#image = file(args.filename, 'rb').read()
#print 'Erasing flash...'
#esp.flash_begin(len(image), args.address)
#seq = 0
#blocks = math.ceil(len(image)/esp.ESP_FLASH_BLOCK)
#while len(image) > 0:
#print '\rWriting at 0x%08x... (%d %%)' % (args.address + seq*esp.ESP_FLASH_BLOCK, 100*seq/blocks),
#sys.stdout.flush()
#esp.flash_block(image[0:esp.ESP_FLASH_BLOCK], seq)
#image = image[esp.ESP_FLASH_BLOCK:]
#seq += 1
#print '\nLeaving...'
#esp.flash_finish(False)
#elif args.operation == 'image_info':
#print ('Entry point: %08x' % image.entrypoint) if image.entrypoint != 0 else 'Entry point not set'
#print '%d segments' % len(image.segments)
#print
#checksum = ESPROM.ESP_CHECKSUM_MAGIC
#for (idx, (offset, size, data)) in enumerate(image.segments):
#print 'Segment %d: %5d bytes at %08x' % (idx+1, size, offset)
#checksum = ESPROM.checksum(data, checksum)
#print
#print 'Checksum: %02x (%s)' % (image.checksum, 'valid' if image.checksum == checksum else 'invalid!')
#elif args.operation == 'make_image':
#image = ESPFirmwareImage()
#if len(args.segfile) == 0:
#raise Exception('No segments specified')
#if len(args.segfile) != len(args.segaddr):
#raise Exception('Number of specified files does not match number of specified addresses')
#for (seg, addr) in zip(args.segfile, args.segaddr):
#data = file(seg, 'rb').read()
#image.add_segment(addr, data)
#image.entrypoint = args.entrypoint
#image.save(args.output)
問候飛出去的朋友遍全球魯迪
Postby yorknh » Thu Apr 16, 2015 10:50 pm
It's a fairly small thing, but I think it would be more intuitive if the function labels in the spreadsheet started at 0 rather than 1. You wouldn't need the paragraph in 2.1 of ESP8266 GPIO Instruction that explains that if you are using function3 of the table the value you write to the register is 2.
Users browsing this forum: No registered users and 47 guests
