SSL connection via AT commands
munderhill
Postby munderhill » Fri Apr 17, 2015 5:53 pm
Is there a way to connect to a secure server (https) using the AT commands? If so, how would that be done?
Re: SSL connection via AT commands
Postby ESP_Faye » Mon Apr 20, 2015 2:17 pm
Sorry for the inconvenience.
We don't have an AT command to create SSL connection now.
You can try to defined your own AT command about SSL.
doughboy
Postby doughboy » Tue Apr 21, 2015 11:59 pm
I am writing AT command to support SSL, but it seems none of the espconn_secure_* api works. At least when I connect to real ssl servers using real cerfificates. (and yes, I have set buffer size to 8196 and use the patched ssl library) esp module will reset (I think due to wdt timeout). I already reported this via email.
Her Majesty
Postby Her Majesty » Wed Apr 22, 2015 10:53 am
doughboy
Postby doughboy » Wed Apr 22, 2015 11:18 am
Her Majesty wrote:Here is a SSL demo http://bbs.espressif.com/viewtopic.php?f=7&t=386
that is just a copy of the iot example program, lol.
I can tell you with absolute certainty, the ssl api does not work.
Postby ESP_Faye » Wed Apr 22, 2015 11:53 am
Thanks for your interest in ESP8266,
Please have a try with the demo code here http://bbs.espressif.com/viewtopic.php?f=21&t=389
Notice that there is a SSL patch http://bbs.espressif.com/viewtopic.php?f=5&t=382
In your case, you need to only change the IP , port and buffer size in user_check_ip , just as below
       const char esp_server_ip[4] = {96, 114, 157, 81};
       os_memcpy(user_tcp_conn.proto.tcp->remote_ip, esp_server_ip, 4);
       user_tcp_conn.proto.tcp->remote_port = 465; // remote SSL port of tcp server
       user_tcp_conn.proto.tcp->local_port = espconn_port(); //local port of ESP8266
       espconn_regist_connectcb(&user_tcp_conn, user_tcp_connect_cb); // register connect callback
       espconn_regist_reconcb(&user_tcp_conn, user_tcp_recon_cb); // register reconnect callback as error handler
       espconn_secure_set_size(ESPCONN_CLIENT,5120); // set SSL buffer size, if your SSL packet larger than 2048
       espconn_secure_connect(&user_tcp_conn); // tcp SSL connect
Please have a try and let me know if your problem be solved or not ?
doughboy
Postby doughboy » Thu Apr 23, 2015 10:33 am
I looked at the sample, and it is similar to my current program.
So I tried to connect to iot.espressif.cn port 8443 and I got a successful connection.
But if I connect to iot.espressif.cn port 443, I get -11. I have already set the buffer to 8192.
you need to make ssl api work with normal websites like smtp.gmail.com:465. Otherwise, there is no real practical use for it other than a novelty API.
I got a firmware with ssl code compiled in 0.93SDK and it is able to connect to smtp.gmail.com:465 just fine, so I think some regression was introduced since then. I compiled my program back to 1.0sdk and they all do not work connecting to normal ssl websites.
This is the log from my program.
AT+CIPSTARTSSL="iot.espressif.cn",443
host: iot.espressif.cn port:443
Free heap: 17680
remote ip 255.255.255.255
using dns
in dns handler
remote ip 115.29.202.58
called connect.
tcp state: 6 error handler:-11
SSL server requires packet size >8192 limit
ERROR
AT+CIPSTARTSSL="iot.espressif.cn",8443
host: iot.espressif.cn port:8443
Free heap: 17680
using dns
in dns handler
called connect.
in listener handler
CONNECT
AT+CIPCLOSESSL
in disconnect handler
CLOSED
doughboy
Postby doughboy » Thu Apr 23, 2015 10:55 am
ok, some correction.
Using exactly the same code, if I used the patched ssl, I get wdt reset. I was using the older libssl.a from 1.0sdk in my previous post. So there is something wrong with the patched ssl library.
Free heap: 17568
buffer size 8192
using dns
in dns handler
called connect.
ets Jan 8 2013,rst cause:4, boot mode:(3,3)
wdt reset
load 0x40100000, len 1320, room 16
tail 8
chksum 0xb8
tail 8
chksum 0xd9
load 0x3ffe8308, len 412, room 0
tail 12
chksum 0xb9
csum 0xb9
2nd boot version : 1.3(b3)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 16Mbit
jump to run user1
doughboy
Postby doughboy » Thu Apr 23, 2015 11:09 am
ok, I tried one more time, using the patched SSL library, but this time, I removed the call to espconn_secure_set_size, and I am able to connect to iot.espressif.cn 8443, but not port 443.
So I'm pretty sure the bug is in espconn_secure_set method. It cause the module to wdt reset.
doughboy
Postby doughboy » Thu Apr 23, 2015 11:12 am
The sample code has the call to espconn_secure_set_size commented out.
I bet if you uncomment that and set size to 8192 and compile that with patched ssl library, you will also get wdt reset.
I tried different values and if I set > 5k, espconn_secure_connect will wdt even connecting to iot.espressif.cn:8443.
I call system_get_free_heap_size() before calling espconn_secure_set_size and I get
Free heap: 17552
So I think there should be memory to malloc a buffer size of 8192.
