Hardware timestamping
aleksei
Postby aleksei » Mon Jul 13, 2015 9:17 pm
IEEE 1588 can be implemented solely in software to give accuracy in the sub-100 microsecond range. This is similar to that seen with other software implemented protocols such as Network Time Protocol (NTP - RFC 1305) and Simple Network Time Protocol (SNTP) methods that operate across the same network topology.
However, if timestamping is performed in the application layer, interrupts and other unpredictable software processes can introduce jitter and latency which may impair the synchronization. Even the use of a very precise external oscillator won't overcome the stack jitter associated with a software-only 1588 implementation.
Most applications require the higher accuracy achieved by timestamping packets at the interface between the physical (PHY) and data link (MAC) layers (often referred to as "hardware timestamping"). IEEE 1588 hardware timestamping typically improves accuracy to 100 nanoseconds or better for certain network configurations, which is better than NTP, SNTP, Time-Triggered Protocol (TTP - http://www.ttpforum.org) and SERCOS (IEC 61491) methods.
http://www.ieee802.org/1/files/public/d ... -0908.pdf4
http://www.ieee802.org/1/files/public/d ... 13-v1.pdf3
Will hardware timestamping support be provided in wifi drivers?
Regards,
Aleksei
Re: Hardware timestamping
Postby ESP_Faye » Mon Jul 20, 2015 4:59 pm
We are assessing it .
We will let you know if there is any update.
