I get 65535 all the time.
In the manual it says
system_get_vdd33 can only be called when TOUT pin is suspended
I do not know what is the case on ESP-01. But let's assume* it is suspended...
I went on reading...
The 107th byte in esp_init_data_default.bin(0〜127byte) is named as
“vdd33_const“ , when TOUT pin is suspended vdd33_const must be set as
0xFF, that is 255
Ok, I thought. Have a look at this file. This is the current (SDK 1.2.0) esp_init_data_default.bin:
05 00 04 02 05 05 05 02 05 00 04 05 05 04 05 05
04 FE FD FF F0 F0 F0 E0 E0 E0 E1 0A FF FF F8 00
F8 F8 52 4E 4A 44 40 38 00 00 01 01 02 03 04 05
01 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00
E1 0A 00 00 00 00 00 00 00 00 01 93 43 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00So byte 107 is 0 by default? This does not seem right to me... Can someone explain?
* If my assumption was wrong and the pin is not suspended... another quote from the SDK:
“vdd33_const”, and when wire TOUT pin to external circuitry, the
vdd33_const must be set as real power voltage of VDD3P3 pin 3 and 4.
Still 0 has to be an incorrect value.
