SPI register and demo
Re: SPI register and demo
Postby kajtusize » Mon Mar 07, 2016 4:08 pm
I've been struggling with SPI slave, almost same story as here viewtopic.php?f=7&t=1540&p=5113
The functions 0x04 and 0x05 are not working, actually I didn't succeed with any function! Any possible update/help!
Thanks!
Thanks!
Postby xPhyiscs » Fri Sep 16, 2016 4:55 pm
Hey !
I have some unanswered questions, which I could not find anything on the internet, about esp8266 , I want to use spi port of esp8266. Before it I check with probe the clock pin, there are huge noisy data or ı do not understand what it is ! I never see such a clock signal before. image is the below from the scope
I do not try the code you give above, If I try it , it will work ?
I work with nodemcu esp8266 , there is no problem like that , when I take the board there is no clock signal so I can simply use the spi port of the board?
I need information about spi port of the esp8266 what you produce. My knowledge just in limitation that it is connected to flash chip to get data !
Thanks for help..
- SCR03.PNG (9.51 KiB) Viewed 25548 times
- SCR04.PNG (9.24 KiB) Viewed 25548 times
Thanks for help..
Postby pratik » Sat Sep 17, 2016 8:33 pm
If you are using the Espressif nonOS or RTOS SDK to write your application, please use the following to set the GPIO to act as HSPI interface pins:
// Configure MUX to allow HSPI
WRITE_PERI_REG(PERIPHS_IO_MUX, 0x105);
// SCK, MOSI, MISO and CS
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 2);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 2);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 2);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 2);
Not writing the correct value to the IO_MUX will cause problems like this in most cases.
Postby pratik » Mon Sep 19, 2016 11:02 am
It is definitely possible, provided you code things right. Be it Arduino or any other interface - in the end it comes down to writing the proper values to the appropriate registers.
I personally am not familiar with the Arduino IDE + ESP8266 so I cannot help with this directly. But there might be libraries that get the job done.
Postby xPhyiscs » Mon Sep 19, 2016 2:22 pm
Actually I am not fan of arduino ide.
To use esp which development environmet should be better ? Can you give me any link to set up ? Ayn tutorial ?
Also how can you learn this ? Where can I find documantation about these ?
Users browsing this forum: No registered users and 291 guests
