Host pcb pads for wroom-02
Postby RogerFL » Thu Jul 30, 2015 9:05 am
Espressif fan and developer of flame boss smoker controller
Espressif_Kelly
Re: Host pcb pads for wroom-02
Postby Espressif_Kelly » Tue Oct 13, 2015 8:38 pm
The original size of pads on ESP-WROOM-02 is 0.9x0.85mm(omitting the cutout half circles on edge pads).
It is ok that the host pads extend further outward(e.g. 0.9x2mm).
Postby RogerFL » Fri Oct 16, 2015 10:39 pm
Please can Espressif publish a recommended PCB layout?
I also see there is a large pad on the bottom which is not mentioned in 0C-ESP8266__WROOM_WiFi_Module_Datasheet__EN_v0.4.pdf
What is the exact position and dimension of that? What signal is it, ground? Should the host PCB layout have that?
This is basic info that is required to design host PCB and it makes me concerned whether I'm making a mistake selecting esp8266-wroom-02 for a real product with 10,000+ units per year projected. This is a real product intended for commercial use, right?
Roger
Espressif_Kelly
Postby Espressif_Kelly » Tue Oct 20, 2015 2:52 pm
You can get the hardware design of ESP-WROOM-02 module at below link.
http://bbs.espressif.com/viewtopic.php?f=51&t=818
Please be noted that the schematic needs to be opened by Orcad Capture16.6 and the PCB layout needs to be opened by Pads Layout 9.5.
Any more questions, please let us know.
Postby comino » Thu Oct 22, 2015 11:49 pm
RogerFL wrote:Thank you Kelly.
Roger
I have the same question - I can fin no information about the pad under the ESP8266 in the datasheet. I almoast destroyed the first pcb layout. What is it conencted to? Ground? Can I use it as a heat sink (we can realy need that)?
Espressif_Kelly
Postby Espressif_Kelly » Wed Oct 28, 2015 7:13 pm
Do you mean pad under the ESP8266EX chip or ESP-WROOM-02 module?
The PAD under ESP8266EX chip is ground PAD (3.7x3.7mm) which must be connected to the ground.
The PAD under ESP-WROOM-02 is also a GND PAD (4.3x4.3mm) which you can connect to ground(for good heat dissipation ) or not, because there are already ground PAD in the pin-out of the ESP-WROOM-02 module.
The Dimension of this GND PAD under ESP-WROOM-02 is as shown below.
Postby RogerFL » Fri Nov 06, 2015 4:48 am
Meanwhile I will look for the software needed to read the footprints. I use a Eagle on a mac so it will take some work. A drawing with the dimensions of the outline and the other pads would still be helpful, but not necessary.
Thank you for the info.
Roger
