请求esp8266 iis dma寄存器描述
Re: 请求esp8266 iis dma寄存器描述
Postby ESP_Faye » Mon Sep 21, 2015 6:37 pm
您好,
I2S demo 和文档如附件。
感谢贵司对 ESP8266 的关注!
I2S demo 和文档如附件。
感谢贵司对 ESP8266 的关注!
- Attachments
- app.zip
- (425.54 KiB) Downloaded 1070 times
- 8P-ESP8266 I2S Module description__CN_v1.0.pdf
- (590.04 KiB) Downloaded 1239 times
Postby ESP_Faye » Thu Sep 24, 2015 7:18 pm
您好,
请参考如下定义:
请参考如下定义:
#define ETS_SLC_INUM 1
#define ETS_SLC_INTR_ATTACH(func, arg)\
ets_isr_attach(ETS_SLC_INUM, (func), (void *)(arg))
#define ETS_SLC_INTR_ENABLE() \
ETS_INTR_ENABLE(ETS_SLC_INUM)Re: 请求esp8266 iis dma寄存器描述
Postby danshi126 » Thu Sep 24, 2015 9:40 pm
Hi Faye,
1、采样率以及位时钟,是用什么公式计算?
注:用esp8266_mp3_decoder SDK里的i2sSetRate计算出来的数据和您设置的数值不一样
2、I2SCONF第12~15Bit 分别表示的含义?
以下是esp8266_mp3_decoder SDK里的i2sSetRate:
#define BASEFREQ (12000000L)
#define ABS(x) (((x)>0)?(x):(-(x)))
//Set the I2S sample rate, in HZ
void i2sSetRate(int rate) {
//Find closest divider
int bestbck=0, bestfreq=0;
int tstfreq;
int i;
//Calculate the base divider for 16 bits of data
int div=(BASEFREQ/(rate*24)); //24Bit 位宽
//The base divider can be off by as much as <1 Compensate by trying to make the amount of bytes in the
//i2s cycle more than 16. Do this by trying the amounts from 16 to 32 and keeping the one that fits best.
for (i=16; i<32; i++) {
tstfreq=BASEFREQ/(div*i*2);
// printf("Best (%d,%d) cur (%d,%d) div %d\n", bestbck, bestfreq, i, tstfreq, ABS(rate-tstfreq));
if (ABS(rate-tstfreq)<ABS(rate-bestfreq)) {
bestbck=i;
bestfreq=tstfreq;
// printf("ReqRate %d Div %d Bck %d Frq %d\n", rate, div, bestbck, BASEFREQ/(div*bestbck*2));
os_printf("bestbck = %d, div = %d\n\r",bestbck,div);
#if 1
//Master mode
CLEAR_PERI_REG_MASK(I2SCONF, I2S_TRANS_SLAVE_MOD|
(I2S_BITS_MOD<<I2S_BITS_MOD_S)|
(I2S_BCK_DIV_NUM <<I2S_BCK_DIV_NUM_S)|
(I2S_CLKM_DIV_NUM<<I2S_CLKM_DIV_NUM_S));
SET_PERI_REG_MASK(I2SCONF, I2S_RIGHT_FIRST|I2S_MSB_RIGHT|I2S_RECE_SLAVE_MOD|
I2S_RECE_MSB_SHIFT|I2S_TRANS_MSB_SHIFT|
(((bestbck-1)&I2S_BCK_DIV_NUM )<<I2S_BCK_DIV_NUM_S)|
(((div-1)&I2S_CLKM_DIV_NUM)<<I2S_CLKM_DIV_NUM_S)|
(8<<I2S_BITS_MOD_S));
#else
//Slave mode
CLEAR_PERI_REG_MASK(I2SCONF, I2S_RECE_SLAVE_MOD|
SET_PERI_REG_MASK(I2SCONF, I2S_RIGHT_FIRST|I2S_MSB_RIGHT|I2S_TRANS_SLAVE_MOD|
(((div-1)&I2S_CLKM_DIV_NUM)<<I2S_CLKM_DIV_NUM_S));
#endif
Postby ESP_Faye » Fri Sep 25, 2015 6:44 pm
您好,
-> SCK 的频率 = 2 × 采样频率 × 采样位数
对于 2 声道 24-bit 数据 32K 采样率,时钟的频率是 32k*2*24 = 1.53MHz
不分频的时钟是 160M,分频一个是 26 一个是 8,1.53 = 160*2/26/8。
12 ~ 15bit 的值 a (a的值为 0 到 8),设置以后,代表我们的 I2S 传输 (16+a)-bit 的数据。
