RTOS版本wifi_station_scan为什么总是失败
Lucifer3502
Postby Lucifer3502 » Thu Aug 20, 2015 9:27 am
代码如下:
wifi_set_opmode_current(STATION_IF);
if(!wifi_station_scan(NULL, wifi_station_scan_cb))
printf("station scan failed.\r\n");
执行结果总是打印station scan failed.为什么呢?
Re: RTOS版本wifi_station_scan为什么总是失败
Postby ESP_Faye » Thu Aug 20, 2015 1:52 pm
您好,
请勿在 user_init 中调用 wifi_station_scan,ESP8266 station 接口初始化完成后,才可以扫描附近 AP。
您可以参考如下代码:
void scan_done(void *arg, STATUS status)
  uint8 ssid[33];
  char temp[128];
  if (status == OK)
    struct bss_info *bss_link = (struct bss_info *)arg;
    bss_link = bss_link->next.stqe_next;//ignore the first one , it's invalid.
    while (bss_link != NULL)
      memset(ssid, 0, 33);
      if (strlen(bss_link->ssid) <= 32)
        memcpy(ssid, bss_link->ssid, strlen(bss_link->ssid));
      else
        memcpy(ssid, bss_link->ssid, 32);
      printf("(%d,\"%s\",%d,\""MACSTR"\",%d)\r\n",
                 bss_link->authmode, ssid, bss_link->rssi,
                 MAC2STR(bss_link->bssid),bss_link->channel);
  else
     printf("scan fail !!!\r\n");
void user_scan(void)
    // wifi scan has to after system init done
   if(wifi_get_opmode() == SOFTAP_MODE)
     printf("ap mode can't scan !!!\r\n");
     return;
   wifi_station_scan(NULL,scan_done);
void scan_task(void *pvParameters)
    printf("Hello, welcome to scan-task!\r\n");
    user_scan();
while (1) {
void user_init(void)
   //Set softAP + station mode
   xTaskCreate(scan_task, "scantsk", 256, NULL, 2, NULL);
